Two stroke oil in the fuel? - Diesel Forum - TheDieselStop.com
Old 12-21-2008, 08:55 PM   #1 (permalink)
tbpower's Avatar
I heard some people run the two stroke oil in the diesel. I usually try to run a gallon or two of b20 per tank or power service. I would use b80 or higher but can't get it here. Just wondering what everybody recommends?
2000 7.3 powerstroke. PHP 6 position chip (stock,high idle,60tow,80dd,100hp,no start) . 6637 riffraff filter kit . AIH delete. Oil crossover. 6.0 tranny cooler. In tank mods. Wicked Wheel. EBPV delete. Walker 21470 muffler. Riffraff FRX
tbpower is offline
Old 12-21-2008, 09:07 PM   #2 (permalink)
chris u's Avatar
I have tried the 2 stroke oil some say it helps but didn't notice much difference. I normally run the power service white bottle in the winter and the silver in the warmer months.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 12-23-2008, 12:08 PM   #3 (permalink)
Spencnaz's Avatar
My Photos: (14)
2 Stroke oil isn't going to help you that much. Stick with B20 in your diesel. Just running B1 improves the lubrication qualities of ULSD by 65%.
2 stroke oil is going to make you pollute more too.
Spencnaz is offline
Old 12-23-2008, 12:19 PM   #4 (permalink)
tbpower's Avatar
I heard you are suppose to use the smokeless/ashless formula of the two stroke. Some swear by it but I'm kind of leaning toward sticking with the bio. I wish they sold the b99 here; I would like to use about a half gallon to a gallon per tank.
tbpower is offline
Old 12-23-2008, 01:41 PM   #5 (permalink)
Spencnaz's Avatar
My Photos: (14)
Just stick with the biodiesel even at 20%. Biodiesel studies have been done for the past 25 years and have shown no negative side affects aside from a injector coking from poor quality fuel.
2 stroke oil is meant for 2 stroke engines. Biodiesel has been tested by Detroit Diesel, Caterpillar, Cummins and International.
They'll only warranty 5% but that's just a legal CYA to keep themselves protected from poor quality fuel.
John Deere fills their tractors with B100 from the factory.
Spencnaz is offline
Old 12-23-2008, 02:13 PM   #6 (permalink)
Going_Going_Gone's Avatar
I've tried it...approx one oz/gal. As far as polluting more, I just had mine emissions tested. Opacity standard = 40.0, my reading = 0.60 My fuel cost spreadsheet shows that it gives me a 1 mpg improvement. When fuel cost was over $5/gal it was worthwhile; at below $3/gal, I'm pretty sure it is negligable. However, I am using it for its lubricating benefit--still running my original C94 injectors and those other additives are technically 'solvents.'
December, '02 build F-250 CC 4X4 Lariat 6.0/Torqshift,Toreador Red over Arizona Beige 4X4 FX4 w/ moon roof. Stull grill insert, chromed tow hooks/bed tie downs, painted door handles, King Ranch flares, '08 aluminum differential cover, Inyati bed liner, Edge 3" lift Bonspeed eight spoke wheels w/BFG AT KO 305/65R18s Pics http://community.webshots.com/user/going_going_gone
Going_Going_Gone is offline
