VEG flash heater design
I am trying to make my centrifuge setup a bit more efficiant, so instead of heating my oil with a single hot water element for 4 hours, I have been thinking about a way to heat it up in route to the centrifuge. What I had in mind was a steel pipe with a heating element on each end... The oil hits the first one on its way to the centrifuge, goes up a length of pipe and hits another on its way out. The pipe would be about 1 1/4" thick (or whatever the threads on a heating element require) set vertical and about 3 feet in length. One element on bottom one on top, with a drain valve on the bottom before the pipe starts, so I can drain after cleanings. The question is... Does the pipe need to be shorter or longer to ensure that maximum heating occurs before it hits the centrifuge? My goal is to have 215* before it goes into the centrifuge. Any ideas on how to make this happen?  Thanks
Greasy
2001 Excursion 7.3l 131,270 mi
aFe Stage 2 Cold air intake
4" exhaust no kitty
Autometer Trans, EGT, WVO Fuel Level, and Boost gauges
4 pod A pillar
Turbo Master Wastegate Actuator
Vegistroke V3(Smells like angry Oil Shareholders...)
27 gal Custom Underbelly WVO Tank
Investigating:
DP Tune
Stand up against the pump! Switch to vegi, hybrid, solar or whatever people cannot use to regulate YOUR life!
