Veggie cleaner - Diesel Forum - TheDieselStop.com
Old 12-31-2007, 08:29 PM   #1 (permalink)
Veggie cleaner
I'm going to be revamping my veggie system so I taking it all apart and under my toolbox I have about an 1 1/2" of veggie funk grime. I've tried all sorts of stove to clean out my bed from pressure washers ,gas ,diesel,engine degreaser, 409, oven cleaner, and the best i've found is dish detergent and a wire brush. Didn't know if anyone knew of anygood solvents. Oh yeah I've also tried bio and glycerine didn't work either.
01 F-250 Superduty XL 133,500 miles
31,500 miles on veggie
Ditched the Auto trans 4R100
6-speed Handrattla...
Clutch pedal
FASS pump
DP 80hp econo tune
Veggie oil undercoating and bedliner
Homemade veggie kit based on FN74
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
more rust............
Spotty is offline
Old 12-31-2007, 10:16 PM   #2 (permalink)
Re: Veggie cleaner
What no one has made a veggie funk mess and had to clean it?
Clutch pedal
FASS pump
DP 80hp econo tune
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
Spotty is offline
Old 12-31-2007, 11:22 PM   #3 (permalink)
hheynow's Avatar
Re: Veggie cleaner
B99 followed by Simple Green plus a lot of elbow grease has always worked for me on painted surfaces and glass. I'd think that a scalding hot pressure washer would do a good job in your bed.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 01-01-2008, 04:50 AM   #4 (permalink)
Send a message via AIM to VD350
Re: Veggie cleaner
The dollar store carries a degreaser called "Awesome", get a bottle of that followed by Simple green. Only way i could clean up the spills by the fuel door
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
