Veggie problems??? - Diesel Forum - TheDieselStop.com
Old 06-16-2004, 07:52 PM   #1 (permalink)
Veggie problems???
I posted this on the 94-97 forum, but I thought I would do it here as well. I was losing power this morning, so I just figured my seperate veggie filter was overdue to be changed and I switched over to diesel. This helped for a while, but as the day progressed and I was still on diesel, I was experiencing a power loss. Eventually I had to be towed home, because it wouldn't start. I replaced the stock fuel filter and tried cranking it repeatedly and still no results.
I honestly don't think this is a veggie problem. I think there is something else going on--I just have to find out what that is.
Any thoughts or ideas would be greatly appreciated.
[img]/ubbthreads/images/graemlins/confused.gif[/img]
97 F250 PSD, 4x4, SC, long bed, 4.10 rear, Tymar intake, Tru-cool 4590, DPPI dp, Autometer pyro & tranny guages, 125K
Alpine CD player, Infinity Reference speakers all the way around.
Converted to run on straight vegetable oil at 96,395 miles--I'll keep ya updated.
wellrooted is offline
Old 06-16-2004, 09:15 PM   #2 (permalink)
My Photos: (20)
Send a message via ICQ to GraemeDiesel
Re: Veggie problems???
Well, I really don't know, but if you are accepting WAGs, I'll guess bad fuel pump. Have you checked the fuel pressure? Second guess, injector pressure regulator. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2003 F350 SRW Crew Cab 6 liter PSD, Torqushift Transmission, 4x4, 606,000 kms
1996 F250 XL, Powerstroke, Swamp's Baby injectors and TS 3 position chip, Tymar intake and downpipe, 4 inch straightpipe, amsoil engine oil bypass filter, coolant bypass filter, 203 thermostat, chevron synthetic oils front to back, 4x4, 5 Speed, Luk single mass flywheel
382,000 kms
GraemeDiesel is offline
Old 06-16-2004, 09:32 PM   #3 (permalink)
My Photos: (6)
What % blend were you running?
It may be possible that the in tank screen got plugged with fats. I dont know if your truck has a screen though......
If not that, then is sounds like the IP if all the filters are clean...
Diesels:
Duramax, ZF-6, CAT 2, B50++
VW TDI 5 speed, 50 MPG
Kubota L4300 DT, custom pintle type hitch on box, avocado hauler
83 Volvo 244 GL, 2.4L NA, Diesel, Manual, 140k+, For sale!
biodiesel from leoco.com
What Would Reagan Do?
mannytranny is offline
Old 06-16-2004, 09:33 PM   #4 (permalink)
My Photos: (20)
The first step is to check and see if there is any air in the fuel system, and if there is, the next is to bleed it out. Normally if a PSD gets some air in the system (from running a fuel tank empty before switching or something like that) it can automatically bleed quite a bit of air on it's own. However with the return line blocked from returning fuel and air to the tank, it's ability to bleed itself may be significantly impaired. To me not having a return line appears to be one of the biggest faults of the greasel system. Every diesel engine I have ever looked at had a return line, and I think manufacturers don't just put them there for no reason.
382,000 kms
Old 06-16-2004, 09:34 PM   #5 (permalink)
My Photos: (6)
Ooops, I looked at your sig, so you are running a converted system somehow......
Diesels:
Old 06-16-2004, 10:41 PM   #6 (permalink)
sounds like the filter is plugged--or theres another screen in the bottom of your fuel filter--that may be plugged also--have to look in past posts for the location of that other screen
94_turbo is offline
Old 06-16-2004, 10:44 PM   #7 (permalink)
I hate to even mention this but, is it possible you have some coke on the injectors?
Mike
1995 F 350 CC PSD 4X4, 4.10's with E4OD. DIY open element air intake. DPP Downpipe. 10K mod, Fumoto drain valve, SCMT 1705, Shimmed FPR, Stancor GP thingy. BDP Stg I's. Panasonic HU feeding an Orion 800.2 for the two 12" JL's and an Orion XTR400.4 for the Infinity 6.1's Yeah its a diesel but I cant hear it from inside the cab. 5 " open exhaust is installed, she barks now! Isspro Trans,Pyro & Boost on the A pillar. Tru-Cool 28,000# stacked plate trans cooler. bdp Stg I's and a UCC TC and Trans-go Tugger kit to hold it to the ground.
Purchased 9/29/03 @ 108,000 mi
As of 12/25/05 its @ 160,000 mi
Upcoming mods- ?
Also play with a '65 Mustang "ground upped" and a customized 92 Harley. Life is good.
My pics
95_stroker is offline
Old 06-16-2004, 11:02 PM   #8 (permalink)
My Photos: (20)
While you are at it, clean your fuel pressure regulator screen. It can inhibit power slightly if it gets badly enough plugged.
382,000 kms
Old 06-17-2004, 05:54 PM   #9 (permalink)
I haven't checked fuel pressure--don't know how to be honest. I changed both stock and veggie filters and checked the screen at the top of the filter--clean. Greasel does put a return line in their systems, but for some reason it doesn't seem to be purging. I drove it around today for quite a few hours trying to purge it. During that time I had periods where it ran quite well and then it would go downhill again, so I believe that pretty much rules out the injectors. I really suspect the fuel pump or simply not being able to purge the air for whatever reason. Unfortunately, I don't have enough diesel knowledge to really troubleshoot the thing. I'll play around with it tonight and if I can't get it, I'll probably have it towed to a mechanic and have them laugh at me--hey, someone's gotta entertain the world.
Thanks for the ideas
Old 06-17-2004, 10:42 PM   #10 (permalink)
My Photos: (20)
If it has a return line it should be able to purge the air out on it's own quite quickly. In checking to see how far I can go on a tank of fuel I have run one tank empty before switching to the other one, and the engine was back to full power within 10 seconds. (I wouldn't do that often, though, because it is probably hard on the fuel pump to run air through it)
So if you are having problems with air in the system it is probably either a bad fuel pump, or else it is sucking air in somewhere.
If it is sucking air in then either you have developed a leak in the fuel line, or else there is a clog somewhere in the fuel line which is partly blocking the flow of fuel and causing a vacuum to develope and making it suck air in where it otherwise would not.
My money (2 cents) is still with the fuel pump being the culprit.
382,000 kms
Old 06-17-2004, 10:47 PM   #11 (permalink)
My Photos: (20)
I'm not sure which screen you mean. The Fuel Pressure Regulator screen? (FPR bolts to the driver's side of the fuel bowl, and the screen is between the bowl and the regulator)
382,000 kms
Old 06-18-2004, 11:09 AM   #12 (permalink)
Yeah--that's the screen I'm talking about. I think it's the pump as well.
Old 06-21-2004, 01:52 PM   #13 (permalink)
My Photos: (21)
Just to let y'all know -- wellrooted replaced his fuel pump over the weekend and that seems to have fixed the problem. You can read all about it here.
<font color="blue">Shoebear</font>
____________________________________
97 F-350 XLT PSD TDE1 crew long bed 4x4 automatic 4.10 SRW Line-X, Filtration Solutions FS-2500 bypass filter, TYMAR intake & HPX, Drawtite 65015 front receiver, Mag-Hytec on diff & trans, Banks downpipe & exhaust, Rancho 9000's, Velvet Ride's, Hypertech PPIII, Westach boost/EGT & trans/diff temp gauges, 2-pod A-pillar mount, Turbo Temp Monitor, Jordan brake controller, Stancor 586-902 GPR. BTS tranny 1/04, Delvac 1, JS IDM, beddins fuel system.
Colorado Springs, CO -- at the foot of Pikes Peak.
shoebear is offline
