Re: Walbro Marine Pump for WVO
I think you two are talking about two different types of pumps. The first is talking about fuel pumps in the vehicle, the second about pumps for gathering veggie oil.
I tested the Facet pump with warm veggie and found it quite adequate. I'm using one on the veggie side to push it through the large Racor 6120 filter and to the Pollak 6-port solenoid. From there the stock fuel pump pushes it on toward the factory fuel filter, etc.
As for those little "drill pumps" they do work but the duty cycle is pretty short. Even if the pump can handle it, I wouldn't want to run my electric drill for 20 or 30 minutes at a time.
Todd T
