Want to start brewing my own bio diesel, I'm just very affraid of hurting reliability. - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-14-2007, 12:09 PM   #16 (permalink)
Re: Want to start brewing my own bio diesel, I'm just very affraid of hurting reliability.
You apparently have this down pretty well. I live in
a regualr subdivision. Can I do this in the city without
neighbors complaining about any strange odors? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 08-14-2007, 02:44 PM   #17 (permalink)
Depends on the subdivision & local ordinances. Do you have a Homeowner's Association? Read your CC&R's and check with your neighbors to see if they'll have kittens. The two most hazardous materials to store are the KOH & Methanol. If your making small batches you won't have much of the methanol on site, but if you want to keep costs down & make some good sized batches, you'll need a 55g drum of a highly flammable liquid on site.
OMCUSNR is offline
Old 08-14-2007, 04:39 PM   #18 (permalink)
If you are looking to make the most fuel with the least amount of time and physical space, get a biopro..
Check out www.murphysmachines.com for more info.
There are several types of processors available.. just make sure whatever you get or build is made of STEEL only.. no plastic.
While the above may seem like an advertisement, you should really ignore it.. (kind of)
What you should do is go here www.biodieselcommunity.org and learn to make a small batch so you know what's involved. Once you do that, you'll have a much better understanding of what to buy.
Murphy2000 is offline
Old 08-14-2007, 04:40 PM   #19 (permalink)
I know a couple guys who make bio in subdivisions but they are pretty nervous about it, if you have nosy neighbors I would think you may have trouble.
03 F250
Factory towing package
Super Chip tuner, performance tune installed
fabricator01 is offline
Old 08-14-2007, 05:10 PM   #20 (permalink)
Large garage on a large lot with neighbors that dont care. Its all inside so the only way someone would see it was if the broke into the garage and looked around.
Everything is vented through the roof with fans so by the time any fumes hit outside they are disapated pretty well.
taxmame is offline
Old 08-14-2007, 08:37 PM   #21 (permalink)
Send a message via AIM to VD350
Basically spend 30 minutes heating the oil (we use 1 water heater element in our 55 gal drum and a second as a back-up), spend 5 minutes titrating, put the lye in the methanol and stir it all up, then pour in. 1 hour and 15 minutes later add your 3 gallons of water, agitate for another 15 min and just bubble it till morning. In all reality you'll spend 30 minutes of your time making 40 gallons at a time in our case.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-14-2007, 10:31 PM   #22 (permalink)
VegieDiesel, is your process different than others? Some say it takes 3 days, some say 5 hours. I still have quite a bit to learn.
What do you guys think of a fully automatic system like this?
http://www.sweethomebiofuel.com/
I talked to the guy today on the phone. They said all you do is put the stuff in their own tanks, push the green button, and 5 hours later you're ready to pump it into your fuel tank. Cost is $5500 for the 50 gal size, $6500 for the 100 gal.
That's a lot of money, but it is a tax write off and comes with a one year warranty. It would be nice to have such an easy system to use.
I figured it would take me at least 2 years to pay for itself.
Maybe I'll come across something that's still fairly easy, but doesn't cost so much.
Early 99 7.3 F250 Extended cab 4x4 6-speed 200,000 miles DIY intake, MBRP 4" single exit, Isspro EGT and boost, DP Tuner 80 econo flash, South Bend clutch Carbotech Bobcat front brake pads, Door seal and Snowman mods...
Steve91T is online now
Old 08-14-2007, 10:54 PM   #23 (permalink)
It's up to you of course but like Murphy said, I would never use a plastic reactor(Think chemicals, heat, leaks) and I'm not gonna say the guy is lying but I think he is FOS.
03 F250
Old 08-14-2007, 11:29 PM   #24 (permalink)
I agree, stay away from plastic and methanol. We use a plastic tank but just for bubbling.
Same process as everyone else for the most part. 120* for 1hour and 15 minutes, add 3 gal of water and circulate for 15 minutes. Mist 3 or so gallons on top of the bio you just did wait 3 hours and bubble till morning.
The one day I forgot to do the 3hr BS and just let the stuff bubble like normal and it was some o the best lookin stuff I've made. i could see my truck shine through it [img]/ubbthreads/images/graemlins/laugh.gif[/img]. Of all the methods we have tried, Bubble drying is by far the best.
And I believe you asked about the by product. We get about 12 gallons of glycerin/water off of the bio. The glycerin burns very nice or can be placed in a nice hole so it can return back to nature. After all were eco friendly people here right? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
www.Fordemblem.com
VD350 is offline
Old 08-15-2007, 01:01 AM   #25 (permalink)
If you want a fully automated system get the Bio Pro. Eight grand is a chunk of change, but I love mine. I'll send you a PM, but they take up to a week to get thru. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 08-15-2007, 01:29 AM   #26 (permalink)
Plastic tanks are dangerous and anyone who designs a system that uses them is just taking your money. That's why they use the plastic tank.. it cost to much to make it out of steel and they don't get their 190% profit margin. By going with a plastic tank, they get to sell you a $400 tank for $3000 or more.
Stick with a steel processor.. automated or not.
Check out www.utahbiodieselsupply.com for an all steel modular processor you can build yourself. (if you can weld)
Old 08-15-2007, 08:02 PM   #27 (permalink)
Or check out www.murphysmachines.com [img]/ubbthreads/images/graemlins/wink.gif[/img]
03 F250
