Water Injection - Page 5 - Diesel Forum - TheDieselStop.com
Old 11-10-2012, 06:58 PM   #61 (permalink)
Great chart airfooter.
Jerry
2000 F250 Superduty 180K and counting 4X4 4R100 Glow Shift gauge - EGT - Boost - Tranny Temp Fuel Pressure on an A pillar mount Diesel Site boots Transgo shift kit K & N Stage II air filter 5" exhaust RiffRaff AIH to boost mod CCV mod DP-Tuner with W85 settings Amsoil Bypass oil filter 6.0 tranny cooler, W80, Cooling Mist water injection.
F250Truckin is offline   Reply With Quote
Old 11-11-2012, 08:28 AM   #62 (permalink)
What is the difference between wood alcohol and methanol? The dictionary says they are the same, but I have heard somewhere recently not to use wood alcohol. Why not? What is the difference? Methanol doesn't seem that easy to find but wood alcohol is everywhere.
Jerry
Old 11-12-2012, 09:16 PM   #63 (permalink)
Well, the project is started. I pulled the CAC tube today and drilled and taped the holes for the injectors. I plugged them until I'm ready to put the jets in and hook it up. Tomorrow will be wiring.
Jerry
Old 11-13-2012, 07:10 AM   #64 (permalink)
My Photos: (6)
Jerry,
Years ago, methanol came from wood. Some still call it wood alcohol. Today though, it all comes from natural gas regardless of what you call it.
Please keep us posted on your results!
ToddT is offline   Reply With Quote
Old 11-13-2012, 07:52 PM   #65 (permalink)
Get it together yet?? 300+ miles on mine so far with absolutely zero smoke. Will keep updating.
takotruckin is offline   Reply With Quote
Old 11-14-2012, 02:59 AM   #66 (permalink)
I am working on a box to ride in the bed that will have the bottle, pump and solenoids in it. I'm hoping to make it so that you can open the lid to add fluid and open one side to inspect - repair - alter the goodies inside. Should get to the install part today. Having a terrible time getting the right tubing T to fit the MAF tube. Should go a lot faster now. I'm also looking for a source for methanol. I have to have something to get through the winter. Antifreeze might not be the answer.
Jerry
Old 11-14-2012, 05:26 AM   #67 (permalink)
Use windshield washer fluid in the winter.
2001 F-350 Nondually. 192K miles. Pretty much stock. DIY SVO Vegistroke style 2 tank conversion April 2010. 70K miles On Vegi!!
simone0414 is offline   Reply With Quote
Old 11-14-2012, 08:33 AM   #68 (permalink)
The stuff I bought is rated at -25. When I put a hydrometer on it, measured +17. I need more than that. I'm going to start with the windshield washer fluid, but graduate when I find something better.
Jerry
Old 11-14-2012, 11:01 AM   #69 (permalink)
airfooter's Avatar
Around here, we can get methanol at a couple of the local race tracks. NAPA can also get it. Reach out to any bio-d makers in your area and see where they get it from. We were buying ours (for bio-d) from a place that makes fuel for RC cars/planes in SC. I still have ~250gals here if ya wanna stop by!
I'd still be surprised if the WW fluid froze at that temp. Have you tried putting some in the freezer? It should be 0*F (or lower).
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/170,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 270k miles on SVO between them!
airfooter is offline   Reply With Quote
Old 11-14-2012, 04:07 PM   #70 (permalink)
JR3342's Avatar
The ag equip dealers have methanol. They use it for antifreeze.
A mercedes window washer tank has a coolant heated coil in it. It's 3/8" line , that with a hoh might work.
99 f250 4Dr short box 7.3 auto 4x2, euro headlights. Diy 6637. 203 thermostat and billet housing. Diy wvo conversion.
92 Mercedes greasecar wvo kit,autometer gauges.
JR3342 is offline   Reply With Quote
Old 11-14-2012, 06:38 PM   #71 (permalink)
Don't tempt me. I'm coming to Hilton Head for the month of January. I'm planning on making a better effort at finding some tomorrow.
Jerry
Old 11-14-2012, 06:56 PM   #72 (permalink)
Jerry perhaps I missed it but what are you using for a WI tank??
Old 11-14-2012, 07:05 PM   #73 (permalink)
JR3342's Avatar
Methanol is the fuel used in most Model airplanes. In the USA methanol is available in small quantities as HEET brand fuel line antifreeze (Yellow bottle)
Found that on a bio diesel site
Old 11-14-2012, 07:31 PM   #74 (permalink)
JR3342's Avatar
Found this too.
+20 F Washer Fluid - Contains approximately 7% methanol.
0 F Washer Fluid - Contains approximately 23% methanol.
-10 F Washer Fluid - Contains approximately 28% methanol.
-20 F Washer Fluid - Contains approximately 35% methanol.
-25 F Washer Fluid - Contains approximately 38% methanol.
-50 F Washer Fluid - Contains approximately 62% methanol.
Old 11-15-2012, 12:17 AM   #75 (permalink)
airfooter's Avatar
Also, 50% methanol/water is 'non-flammable'. Be VERY careful with pure methanol - not only is it very flammable, it burns with a clear flame and is difficult to see. When I brought this stuff home the first time, I demonstrated this to the kids and gave them carte blanche permission to blast anyone approaching the drums of methanol while smoking with the garden hose!!
One more thing, it is highly toxic and inhalation or absorption through the skin can cause blindness and other serious health problems.
