What to change in order to run Bio Diesel - Diesel Forum - TheDieselStop.com
Old 10-16-2007, 03:56 PM   #1 (permalink)
I am thinking of running some BIO. Do I need to change out some of the fuel lines or something? I recall reading someting about the BIO eating up some of the lines.
I have a '97 PSD.
Thanks,
Dan
1st truck: '97 F350 CC SRW, 5 spd, Luk Single Mass Flywheel, Tymar intake, 3" Down pipe and 4" exhaust (no cat), Pac Brake, Warn Premium Hubs, Torklift Super Hitch, Issopro EV Oil Temp, Boost and Pyro 410,000 as of 05-09 and going strong.
2nd truck: 2002 F350 CC SRW Auto, BTS Valve Body, 1.0 Turbo Housing w/o wastegate, EBPV Delete, Tymar Intake, MBRP 4" Turbo back 304SS, Isspro Performax Trans Temp, Boost, Pyro, and Fuel Pressure, 6.0 Trans Cooler, 5150 Bilstiens. And only 52,000 miles as of 06-09.
aerotow1 is offline
Old 10-16-2007, 06:03 PM   #2 (permalink)
Re: What to change in order to run Bio Diesel
i used to run b20 from a local truck stop all the time. didn't change anything and did not have any problems. i have a '94 truck.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 10-16-2007, 07:12 PM   #4 (permalink)
I cannot confirm the following, but have been told by others who have run a B80 and B100, their fuel pumps quit, and had to change fuel filters every other fill up. Again, this may be some serious exageration on their part. This may be a better question posted in the alternative fuel/Biodiesel forum though. Good luck with any switch you choose. I know I've used B20 with no ill effects on numerous occations while traveling.
Bret
97 F250, 4x4, ext. cab., auto, 4:10LS, H-max downpipe, Autometer Ultra-Lite gauges, TYMAR intake (the real deal), TS Chip, Dual Tensioner mod, Amsoil Dual Remote By-pass with AMS-Oiler (pre-oiler), Amsoil throughout, a cracked windshield, WARN Premium manual hubs, and 216K miles (still ticking)
Life Member: Disabled American Veterans
Stong supporter of all US Troops, their families, and all waiting for a safe return. Thank you, from a former soldier and his family
Bret_B is offline
Old 10-17-2007, 02:12 AM   #5 (permalink)
b20 you may need to change a couple of fuel filters it will clean your tanks...also the exhaust smells a lot less harsh compared to regular diesel...2 cents...
Ford F250 Short Bed Extended Cab/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
Old 10-17-2007, 10:53 AM   #6 (permalink)
hheynow's Avatar
After running B100 for a while my return lines melted. There are many of us with 96 & 97s who have had this meltdown. Replaced the return lines with bioD compatible hose and problem solved.
With B20 you should not have this problem. Remove the plastic loam from the return lines to monitor.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 10-18-2007, 10:05 PM   #7 (permalink)
I have been running certified B100 for approx 8,000 miles. Changed fuel filters twice. Just replaced fuel return lines from FPR with Dayco Gen2 lines as the originals were starting to "melt"! No other problems. Engine runs great once it is warmed up but that was the case with Dino Fuel. If I can sort out the winter gel problem, I will never run petroleum diesel fuel again!
Deadbolt in Central PA.
2003 F-350 7.3L SuperCab Lariet, 4x4, 6 spd, 187,000 miles. AMSOIL. Many upgrades.
97 Mercury Sable LS....great car! Owned since new! 174,000 miles. AMSOIL.
96 F-350 7.3L PSD,XLT, Reg. cab.4X4, 5spd, 375,000 miles! AMSOIL. Many upgrades.
91 Mercedes 300D 2.5 TurboDiesel. Just bought @ 193,000 miles young! AMSOIL. Excellent condition!
86 F-350 6.9L, XLT,4X4,C-6,Amsoil front to rear,Michelins,A/R wheels,410,000 miles.
deadbolt is offline
Old 10-19-2007, 12:54 PM   #8 (permalink)
Spencnaz's Avatar
My Photos: (14)
Parker Hose has a biodiesel resistant fuel line that is quite good.
If you have a Parker dealer in your area they should be able to find some or have it in stock.
Spencnaz is offline
Old 10-20-2007, 10:44 PM   #9 (permalink)
I just took the sending unit out of the rear tank of my 87 Ford F-250 that I have been running B-100, The screen and pick up tube were broken (Plastic) has anybody else had this problem? Where do I find the parts? Was B-100 the problem?
alanrpryor is offline
Old 10-20-2007, 10:55 PM   #10 (permalink)
Send a message via AIM to VD350
the old ford are notorious for breaking off pickup lines, thats why many owners dont venture below a 1/4 of a tank. B-100 was unlikely the problem.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 10-20-2007, 11:00 PM   #11 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: alpryor</div><div class="ubbcode-body">I just took the sending unit out of the rear tank of my 87 Ford F-250 that I have been running B-100, The screen and pick up tube were broken (Plastic) has anybody else had this problem? Where do I find the parts? Was B-100 the problem?
Thanks </div></div>
B100 was not the problem. They all do that.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
