What to do with paint smelling veggie oil? - Diesel Forum - TheDieselStop.com
Old 08-22-2007, 03:54 PM   #1 (permalink)
hheynow's Avatar
I have a partial 55 gal drum with veggie oil of unknown origin. It smells like paint and I believe it is oxidized. I have set it aside because I don't care to use it in my WVO converted truck. What should I do with the oil? Take it to the recycle center at my local dump -OR- can it be used to make quality bioD with it being oxidized? I'd rather give it away to someone who would process it than dump it, but never having made bioD I have no idea if this oil will work.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 08-22-2007, 09:22 PM   #2 (permalink)
Send a message via AIM to VD350
Re: What to do with paint smelling veggie oil?
I'd ether burn it or recycle it. I wouldnt tempt fate and try to make it into fuel
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-22-2007, 10:49 PM   #3 (permalink)
Weed Killer
Heating Fuel
Parts degreaser/cleaner
Wasp/Hornet spray? (I'll let you test that one)
Murphy2000 is offline
Old 08-22-2007, 11:02 PM   #4 (permalink)
Don't use it as biofuel... bad news, from various reports. It'll go ahead and change into 'bad biodiesel' (that looks a bit like two biodiesel molecules stuck together, and has higher viscosity than you want) if you try to make it into biodiesel.
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 08-23-2007, 01:22 PM   #5 (permalink)
Spencnaz's Avatar
My Photos: (14)
I'm for the heating fuel solution. Home heating oil is going to be very expensive this year.
Spencnaz is offline
Old 08-23-2007, 02:50 PM   #6 (permalink)
I'm with Spencnaz on that one. But I would make biofuel and use it as heating fuel, not the wvo directly, unless you have a burner that can utilize fuel as thick as vegetable oil...
2000 F-250 Super Cab Longbed
Bright red, they call me "Clifford"
scottefontay is offline
Old 08-25-2007, 11:32 AM   #7 (permalink)
I have a bunch of WVO in 55 gallon drums that smells rancit and I am processing into BioD to use in my Kerosene monitor heater. Worked good last year should work again this year.
01 F-250 Superduty XL 133,500 miles
31,500 miles on veggie
Ditched the Auto trans 4R100
6-speed Handrattla...
Clutch pedal
FASS pump
DP 80hp econo tune
Veggie oil undercoating and bedliner
Homemade veggie kit based on FN74
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
more rust............
Spotty is offline
Old 08-29-2007, 11:10 AM   #8 (permalink)
cardenwh's Avatar
Has anyone tryed using WVO in a home heating system. I just had to buy 500 Gallons of home heating oil. Would be nice to be able to use WVO? Hell if my Car Can run on it a Burner should.
cardenwh is offline
Old 08-29-2007, 12:01 PM   #9 (permalink)
It's not as easy as using bioiesel in a home heating system.
There's not a good web page for all the ways people modify the furnaces, but there's a Yahoogroup that you might want to check out:
http://www.groups.yahoo.com/group/altfuelfurnace
girlmark is offline
Old 08-29-2007, 12:55 PM   #10 (permalink)
cardenwh's Avatar
Thanks! What a GMC GASSSS. Switch to propane!
cardenwh is offline
Old 08-29-2007, 01:06 PM   #11 (permalink)
Spencnaz's Avatar
My Photos: (14)
You haven't seen the van they use! It's awesome, converted to 4WD. I'd buy it if I had the chance.
Spencnaz is offline
