What does everyone think about mixing different used oils - Diesel Forum - TheDieselStop.com
Old 12-19-2006, 11:27 PM   #1 (permalink)
I have a few locations giving oil. When I make my Bio, I usually have 90% oil from the same place. Now, if I was to mix oils that titrate to different levels and I mixed them well will the titration blend or would it be different with different samples?
I mix 40 gallons a time and if there was 5 gallons that wouldnt blend with the other 35 gallons then my titration sample would be skewed and I could be too high or low on the use of KOH
I would also lake to say here that I have made over 700 gallons of Bio that I have mixed and ran with #2 (sometimes as strong as 80% bio) in my 2006 F250 that how has just above 50K trouble free miles
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 F250 4x2, MBPR Exhaust, Factory 20s" w/ 34.2 inch tall tires and 4.10 gear
racing4funn is offline
Old 12-19-2006, 11:42 PM   #2 (permalink)
My Photos: (6)
Re: What does everyone think about mixing different used oils
why not run 100% like the big boys? heheh
2005 YELLOW Ford F-350 Lifted 35 inch Mickey Thompsons Arp Head studs, Buswhacker Flares, Four Real Steel Light Bar, 4 Piaa 525 series fog lights, K&N Air Filter Kit, Cowl induction hood by Reflexxion, Solid billet grille $$... Sct Xcal3 w/ Xtreme Tunes, T409 cat back mbrp exhuast from Innovative. Amp research electric power steps with led light kit
All running on 100% Home-made Biodiesel! .70 a gallon! If interested in biodiesel drop me a pm.
Brentsbg is offline
Old 12-19-2006, 11:58 PM   #3 (permalink)
Seems pretty simple to me but then I use NaOH.
Just titrate both or all the different batches seperatly and if they fall within your parameters mix em up and re-titrate.
I use WVO from 4 different sources and have been very fortunate that they normally fall in the 1 to 2 area... just lucky I guess.
Let us know what you do, be interesting to hear your decision and results.
Skip aka behoof
1996 Ford F250 XLT -- TurboDiesel on BIO -- E40D 250K+ 4x4 Extended Cab "Yale, Mi"
behoof is offline
Old 12-20-2006, 07:35 AM   #4 (permalink)
Why titrate individually? mix them up and titrate the end result.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 12-20-2006, 08:11 AM   #5 (permalink)
agreed, you certainly could do it that way.. my response was based on what I thought might have been the concern that one or more of the batches were way off and you wouldn't want to add that to a really good batch. either way works
behoof is offline
Old 12-20-2006, 09:47 AM   #6 (permalink)
I just didnt know if they would mix.. Meaning that one part needed more KOH than the other. I have been doing it that way and I have always made successful batches so I guess it dosent matter. Just a question of what might be taking place. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
On another note, I thought KOH was more forgiving to use!
Old 12-20-2006, 10:57 AM   #7 (permalink)
I normally mix "bad" oil if it is higher 4-5 with good oil 1-2. i let it mix in my processor for about 5 minutes and it mixes very well. If i test both oils before mixing i can almost always guess the outcome by mutiplying on a percentage basis. I have never had a problem doing this.
2002, f250, 4x4, crew cab, short bed, automatic.
4'' lift and 35'' tires
afe stage 2,
4 inch stainless afe strait pipe.
ts 140 hp chip
autometer guages
150,000k
jasonfordman is offline
