I am in search of a good electric pump to transfer WVO from a 55 gal. drum to a water tank on a trailer and the tank to the processor. Most of the pumps that I have found state they are for clear water use only. Any suggestions would be great.
Mike
01' F250 PSD, CC, 4X4, SWB, Manual, 6in Procomp lift, 315/75/16 BFG T/A KO's, AR rims, Banks Six Gun(with digital Pyro), 75hp TS chip, AEM Dry Flow intake, WW, triple pilar pod, Autometer NV series Boost and Oil pressure, Straight piped exhaust.
i got an air collection pump online on ebay for like $60 and it works real well and fast. theres also no moving parts of motors to fail on it. just type in air wvo pump.
If at all possible, look for a rotary gear pump. It will work regardless of the temperature unless it's REALLY cold.
Centrifugal pumps (like the Harbor Freight blue "clear water" pump) are not self priming. They can't handle thicker liquids nearly as well. A rotary gear pump can handle thick stuff.
I've tried the Northern Tools 12v transfer pump but found it inadequate for cold grease. That is a rotary vane type pump. Fine for warm oil but just unable to push cold grease.
Personally, I use an oil pump from a ford v-8. It is a positive displacement pump, meaning it is self priming. It came with the hex shaft to drive it which I chuck in a hand drill and use to turn it.
It took a bit of work, not much, but it's not ready to go. Took the intake tube off, and welded a 1/2"X3/4" reducer (pipe threads). The 1/2" side goes against the pump, the 3/4" threads have a 3/4" ID nipple on it to attach 3/4" ID tubing as the suction side.
The output has much the same welded to it so the discharge goes through a length of tubing also 3/4".
Same experience here. It works fine for warm weather, but it really bogs down once things get colder. I've also found that a 5.5hp 2" trash pump will really move that stuff, but then again that's not electric like you're looking for.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'04 Jetta TDI, Greasecar WVO conversion
'96 International 3800 school bus, DT466, homemade WVO system, www.thebiggreenbus.org
How does it work in cold temp and cold oil?
Mike
im not sure about cold oil yet as i have just got one this summer. i imagine it would work better than an impeller type pump. i'll keep you guys updated but so far this has been the best oil collection pump investment i have made.
Check out Redline pumps on the internet. They are expensive but they are the very best and have all the accessories you need.
If you like my Avatar, check out my girlfriend at BriannaJordan.com!
03' F350, 6.0, Crew Cab, Six inch lift, Amp Power Steps, Jimmie Jammers. Looking for help and advise to safely upgrade.
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. New custom tranny on the way to get me sub 4 sec. 0-60, top speed of 215mph and about 40mpg all at the same time!
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, over 750 functions. Still don't know them all yet. For Sale! Buyin' a diesel car.
Isn't that only good for about 3.5 gallons per minute? Northern Tool has some listed.. They look interesting otherwise. How much air does it consume?
for clear water use only may work
see if it has a black rubber seal on the pump and on the internal joints and such(where pipes join there may be orings)
and if they are very flexible black rubber youll mostlikely be fine to be sure call the company and ask if they use viton orings or if they dont see what type and pmme ill be able to tell u if its wvo/diesel/wmo compatible or not
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
Thanks for all the input I am going to use a friends 2" gas powered pump, Which he has offered it to me for 150. I dont think i will have any isues with cold oil. Atleast I hope not.
Mike
Do they only work with a SEALED barrel? Or can it work with an open barrel as well?
