Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 10-23-2008, 11:43 AM   #1 (permalink)
VegasDiesel's Avatar
What makes wvo smell so bad?
Is it the bits and pieces of crumbs, food, etc., that just sit in the dumpster and rot? Can it be avoided if you constantly drain it?
03' F350, 6.0, Crew Cab, Six inch lift, Amp Power Steps, Jimmie Jammers. Looking for help and advise to safely upgrade.
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. New custom tranny on the way to get me sub 4 sec. 0-60, top speed of 215mph and about 40mpg all at the same time!
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, over 750 functions. Still don't know them all yet. For Sale! Buyin' a diesel car.
VegasDiesel is offline
Old 10-23-2008, 11:17 PM   #2 (permalink)
what smell? the liquid form or the combusted form??
If your WVO smells that rotten then it might have chemicals in it or it was used too much.
Also depends on type of food that was cooked.
2005 Excursion 6.0l
wilson & Co is offline
Old 10-24-2008, 01:36 AM   #3 (permalink)
I'm talking about the oil at the back of the restaurants. You brought up a point though. When processed correctly, does that terrible smell go away? Does it stink up the garage?
Old 10-24-2008, 09:53 AM   #4 (permalink)
Smell is a individual perception to a large extent.... I like to smell my farts but my wife pukes haha.
I would stay away from TERRIBLE smelling oil. It should only smell like the food that was cooked in it. I would suggest visiting some places that dont use those commercial dumpsters... find a place with a 55gal drum and take a small sample. Try a pizza shop (tho they use pho oil many times fyi)
Alot of those dumpsters I have seen restaurants dumping solid food waste into.
2005 Excursion 6.0l
Old 10-24-2008, 10:24 AM   #5 (permalink)
hheynow's Avatar
Used [dry] oil tends to take on the odor of what was fried in it. Wet oil allows bacterial growth over time. Once rancid I have not found a way to neutralize the odor short of tossing out all the oil and drum. It definitely gives me a gag reflex. Oil stored in an open drum in the hot sun can oxidize over time. Oxidized oil smells like paint or paint thinner and should not be used. To avoid water in the first place it's best to get the drum or dumpster out of the rain but even if wet, it can be filtered, dried and used if not rancid. Maybe you should dose the dumpster with a good biocide?
1997 F-350 PSD RC LB 4WD E4OD - Plant Drive SVO kit
1984 Mercedes Euro 300D NA - Custom two-tank SVO
Using WVO and biodiesel since May 2006
hheynow is offline
Old 10-24-2008, 09:58 PM   #6 (permalink)
as stated--smelly oil is the cause of bacteria growing in it--ive gotten oil like that--i just leave it in the closed drum during the wonderful iowa winters--kills all the bacteria!!!!!!!!!
94_turbo is offline
Old 10-27-2008, 01:42 AM   #7 (permalink)
Thanks so much guys. Anything else?
