Per requests from several on the forum, the following is what is what:
Please PM me if anyone sees anything that should be added.
B20 Mix of 20% biodiesel and 80% Diesel
Bio Diesel is fuel made from oil through a process called transesterifacation. That is the seperation of the glycerine from the esters in the oil. This is what the methanol and lye do. The glycerine is the waste and the esters is the bio-d.
Blended Vegetable Oil Mixing Vegetable oil with a thinning agent to lower the viscosity of the Vegetable Oil so it pumps and injects more like diesel.
FPHE Flat Plate Heat Exchanger
RUG Regular Unleaded Gasoline
SVO is new straight veggie oil (any kind, never used). May also need heated, like WVO.
ULSD Ultra Low Sulfur Diesel
WVO is used veggie oil, usually picked up from a restaurant or food processing plant. Once processed it may need to be warmed in your tank or pickup in colder weather so your engine can use it.
I will edit as I come across clearer or other definitions.
Dave / Believer45
Reason: Add some
1988 F250 SC converted to run dual fuel(Diesel/filtered used fryer vegetable oil) Smells like a Bar-B-Que driving down the road. Chicken one day..pork the next.
The POWERSMOKE
1986 F250 4x4 XLT Lariat Explorer, 6.9 with Hypermax Turbo and cowl induction.
217k miles and climbing, C6 Transmission. Gear Vendors. Dual tanks with 50 gallon tank added to bed, locking canopy. Dana 50 TTB with Ford 10.25 rear and 3.54:1 ratios. Running B100 with no ill effects. Homebrew BioD. 80 gallon biodiesel processor with custom machined vacuum venturi
1973 Dodge Monaco aka 'Elwood', 64K original miles, Dodge steel cop rims with dog-dishes. 400 B-block with single exhaust, due for dual exhaust. Planning on eventually running it on methane. May be up for sale in the near future.
Transesterification (Chemical Conversion of Biodiesel)
The manufacturing of biodiesel from vegetable oils (e.g. soy, canola, jatropha or sunflower seed) or animal fats, involves the base-catalyzed transesterification of fatty acids with methanol or ethanol to give the corresponding methyl esters or ethyl esters. Glycerin is an inevitable byproduct of this reaction.
Vegetable oils as animal fats are triglycerides composed of three chains of fatty acids bound by a glycerin molecule. Triglycerides are esters. Esters are acids, like fatty acids, combined with an alcohol. Glycerine (= glycerol) is a heavy alcohol. In the conversion process triglyceride esters are turned into alkyl esters (= biodiesel) using a catalyst (lye) and an alcohol reagent, e.g. methanol, which yields methyl esters biodiesel. The methanol replaces the glycerin.
The glycerine - the heavier phase - will sink to the bottom. Biodiesel - the lighter phase - floats on top and can be separated, e.g. by decanters or centrifuges. This conversion process is called transesterification.
The conventional esterification reaction in batch processing tends to be slow, and phase separation of the glycerin is time-consuming, often taking 5 hours or more.
100% Disabled Viet Nam Veteran (Agent Orange and its' complications)
SONETIMES I'M ALL CAPS...BECAUSE OF MY DIABETIC EYE DEGENERATION
2009 Mitsubusi Outlander SE
2004 VW Golf TDI - Automatic, 100 HP Diesel gets 38 MPG around town. XM Satellite Radio
2001 Monaco Knight - 265 HP Cummins gets 12.5 MPG towing the TDI
