Where can I get wvo dumpsters - Diesel Forum - TheDieselStop.com
Old 10-26-2008, 10:43 PM   #1 (permalink)
VegasDiesel's Avatar
I've looked everywhere. To clarify, I'm looking for containers like the ones behind the restaurants that belong to the oil collection companies. What do you guys use?
03' F350, 6.0, Crew Cab, 4" lift,
Amp Power Steps,
Jimmie Jammers.
4" Turbo Back MBRP exhaust,
Adrenaline HPOP from Dieselsite.com.
155 injectors, egr fix, ARP studs, black onyx gaskets, and SCT custom tunes. All from River City Diesel!
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. been down for a long time and finally getting my tranny rebuilt to handle the power...I hope.
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, yadda yadda. Always in the shop.
Yes the girl in my avatar is actually "my girl"
VegasDiesel is offline
Old 10-27-2008, 02:51 AM   #2 (permalink)
ajohansson's Avatar
I use a 55 gallon drum and a steel locking drum funnel with a screen inside from New pig corporation. I also use the locking ring to deter theft.
AJ
ajohansson is offline
Old 10-27-2008, 12:01 PM   #3 (permalink)
They are available here. Currently out of stock so I pulled the page down. The units should be here on Friday. They hold 250 gallons (approx).
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 10-27-2008, 09:14 PM   #4 (permalink)
hheynow's Avatar
An option for locking 55 gallon drums HERE .
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 10-28-2008, 12:17 AM   #5 (permalink)
Thanks so much for your help guys. Stormin, can you let me know when the go back up? Thanks.
Amp Power Steps,
Jimmie Jammers.
Old 10-28-2008, 10:11 PM   #6 (permalink)
Send a message via AIM to evolutioncam
Par kan makes the dumpster style containers
Jason Brown
Harleysville, Pa
Repoman Running Biodiesel
www.thebrownsoapcompany.com
evolutioncam is offline
Old 10-29-2008, 02:11 AM   #7 (permalink)
Damn! I've been looking all over for those things. Thanks Jason! I could not have gotten this far without your help.
Amp Power Steps,
Jimmie Jammers.
Old 10-29-2008, 12:23 PM   #8 (permalink)
Here's the Par-Kan dumpster website:
Par-Kan
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
