where does the glycerin come from? - Diesel Forum - TheDieselStop.com
Old 11-21-2005, 04:43 PM   #1 (permalink)
thinking of making some bio with wvo i noticed people washing and draining glycerin, the dse way does not call for this? does the glycerin come from the addition of methanol?
cobra9646 is offline
Old 11-21-2005, 05:26 PM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: where does the glycerin come from?
The methanol when mixed with lye forms Sodium (or Potassium)Methoxide.
This compound causes the glycerin in the WVO to be precipitated out of solution, letting it settle at the bottom of the processor.
It is pretty much agreed upon not only here but on several other biodiesel forums that DSE is a mixed solution of snake oil and other hydrocarbon detritus. Some very very toxic chemicals such as xylol are used in DSE's formula.
Spencnaz is offline
Old 11-21-2005, 06:18 PM   #3 (permalink)
does dse way eliminate the water from the diesel.
i know they use karosyne and regular unleaded in there mixure, not sure why.
Old 11-21-2005, 06:34 PM   #4 (permalink)
Bio-Diesel is technically called "Fatty Acid Methel Ester".
Veggie oil is made up of a Glyceride Molecule with three Fatty Acid Chains attached.
By using an Alcohol and a catalyst, we strip the Glyceride from the three fatty acid chains. The glyceride falls to the bottom, and the fatty acids become the bio-diesel.
This is where the glycerine comes from.
Ford_Forgotton is offline
Old 11-21-2005, 06:50 PM   #5 (permalink)
then how does the dse system get the glycerin out? im just trying to figure out if there system works
Old 11-21-2005, 06:57 PM   #6 (permalink)
Spencnaz's Avatar
My Photos: (14)
I really don't think they are removing the glycerin at all. When looking at all the additives that they are using, I would say that it's thinning the vegetable oil to the point where there are no immediate modifications needed to pump the fuel into the engine.
There have been many posts of fuel pumps either becoming very noise after using DSE to outright failures of the fuel pumps.
Spencnaz is offline
Old 11-21-2005, 07:06 PM   #7 (permalink)
so instead of removing the glycerin they just thin it then. I know they add kerocene and regular unleaded.
how can trucks run straight wvo ? i have seen the trucks with a seperate tank and a switch? thanks for the help , im trying to get all the info before i blow up my truck.
Old 11-21-2005, 09:10 PM   #8 (permalink)
Do a search on "oil can harry" or "OCH". His method of involves using ethanol and KOH to "suspend" everything in the WVO. Nothing gets cleaned out but is thinned to the point of being usable in diesels. It sounds like a very viable method.....however that 10K engine in my truck makes me pretty wary of these other "methods." The stuff they are creating is NOT biod.
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
dssamp is offline
Old 11-21-2005, 09:39 PM   #9 (permalink)
My Photos: (14)
not to steal the post but what do you do with the glycerin after you drain it off? I know it junk but how do you get rid of it?
2001 Ford F-350 crewcab long bed srw black gauges boost and pyro 125 hp chip adjustable 10k-3.9k mod. Straight piped 4 in lift with 35`s X-
Terrain. Aceton emblems <font color="red"> Everyone dies but not everone lives </font>
http://photos.thedieselstop.com/show...=39254&thumb=1
coolua is offline
Old 11-21-2005, 09:49 PM   #10 (permalink)
Actually, its not Junk at all! If you refine it, its used in cosmetics and soap and is worth alot of money!
You will need to evaporate all of the alcohol out of it, and neatralize the LYE with an acid (vinegar works well) until you get a pH of about 7-ish.
It also can be used in a compost pile if you can keep it mixed with other stuff and not a pool of glop.
Burn it in a waste oil burner.
