Where to get a good filter - Diesel Forum - TheDieselStop.com
Old 06-01-2004, 07:29 PM   #1 (permalink)
My Photos: (22)
I need to purchase a good 5 micron filter that I could run inlne on a filter head in the engine compartment. Any ideas?
I got a source on pre filtered WVO, selling for around 90 cents a gallon here in North Texas. Don't know exactly where yet, but am going to find out. However, I am not opposed to doing the filtering myself. There is also a BioD station about 15 miles from the house that is actually between here and where I work. I am in the process of building a tank of about 100 gallons to carry in the bed for the WVO, and would like to pipe it in for highway use, since that is most of my driving. I am thinking that for a heater I would utilize the trucks cooling system to heat the tank from the bottom and sides. i owuld like to run on at least 60% WVO (40% diesel mixed). Is this entire idea feasible?
-Bobby
<font color="blue">True Blue BOOB Man</font>
IDI Help Registry
Lone Star IDI Rally and Events
My Pictures
The Gray Ghost
Manufactured 08/92 F350 N/A CC, 362k Miles, 4x4 w/ E4OD Intstalled, '''Convereted to 6.9L''', 7.3 Maxed IP and 'D' code injectors, Ghost Tube Open Element Filter, Dana 60 pullin' a Sterling 10.25 w/4.10's, 33" Dakota RVT's on American Racing Outlaws, 3.5" w/ Flowmaster 40 series Single Out, Westach Boost and Pyro Gauges, Custom Turbo on the Drawing Board
The Buckin Bronc--'90 Bronco, Eddie Bauer, 302, Auto, Electronic 4wd
"...If wantin' the good life is such a crime, Lord then put me away...", Nothin' But a Good Time - Poison
"It's not a truck, it's a lifestyle."
turbo69 is offline
Old 06-01-2004, 07:38 PM   #2 (permalink)
My Photos: (22)
Re: Where to get a good filter
BTW-
What about adding gasoline to the mix for viscosity thinning and runability in order to be able to run a stiffer mix, say 80 WVO-10 Diesel-10 Gas. And maybe adding in a little stanadyne for the pump and injectors.
See Here
-Bobby
IDI Help Registry
My Pictures
The Gray Ghost
turbo69 is offline
Old 06-01-2004, 08:01 PM   #3 (permalink)
The above site is great and very informative.
04' 6.0 F-250 CC Long Bedwith canopy. 22ft of love.
why73 is offline
Old 06-01-2004, 09:13 PM   #4 (permalink)
guys--i refuse to add gasoline to the mix on even the .01% chance it could ruin my ip----
94_turbo is offline
Old 06-01-2004, 11:37 PM   #5 (permalink)
i have been looking into running straight or mixed veggie oil and im working on filtering it now . im going to try and cold filter it through a semi truck air filter(whitch filters from the inside out) first to remove the big stuff but i cant get a straight answer from the filter manufactures because there air filters are not rated in microns and then im going to use the filters i remove from the trucks i service detroit 60s use 10 micron primary and 5 secondary filters and im going to use them even they are used they aint used up and the price is right and at the rate i put them on i can change them out on a regular basis like about 4 - 6 a week . im going to thin the oil out with the diesel i drain from the filters when i remove them . which im saving in a bucket on the truck and put it in the truck when its full and the best thing is i get them for free and have already located two sources for the oil and am building a tank to pick it
94 f450 superduty, 7.3 idi, factory turbo, e4od trans, 5.13 gears, 14000lbs + across the scales every day of the week, 11'redding utility body, 3 cyl kubota diesel(tied in to truck cooling system)for air compressor , front bumper is 8"x8" square (air tank), 4 group 31s batteries mounted to frame under cab,2 straight stainless pipes pokin up in the air and no muffler(sounds great) now runnin on 100% wvo
2ND IDI
93 F250 XLT 2WD 7.3 IDI E4OD ALL STOCK MORRISON UTILITY BODY 10 horse yanmar diesel on the compressor, batteries relocated to under the the cab on the frame
magyver is offline
Old 06-02-2004, 12:19 AM   #6 (permalink)
My Photos: (6)
fsifilters.com (IIRC) is supposed to send me some free samples.
filterbag.com
Diesels:
Duramax, ZF-6, CAT 2, B50++
VW TDI 5 speed, 50 MPG
Kubota L4300 DT, custom pintle type hitch on box, avocado hauler
83 Volvo 244 GL, 2.4L NA, Diesel, Manual, 140k+, For sale!
biodiesel from leoco.com
What Would Reagan Do?
mannytranny is offline
