Old 12-26-2007, 05:46 PM   #1 (permalink)
Where are you getting the pump&filter(s) to filter the SVO?
Where to buy?
DRPowerStroke is offline
Old 12-26-2007, 08:35 PM   #2 (permalink)
Send a message via AIM to VD350
Re: Where are you getting the pump&filter(s) to filter the SVO?
b100supply.org
Search for "Sock filter" on ebay. When we ran SVO we filtered down to 1 micron
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 12-31-2007, 07:16 PM   #3 (permalink)
1" clear water pump- Harbor frieght or northern tools they have specials alot can get as cheap as 25 bucks sometimes.
US plastics for the drum filters
I use a x-100 filter housing with a 5 micron sock filter
and 2 whirlpool water filter housings with 2 micron filters from Home Depot or your local hardware store.
01 F-250 Superduty XL 133,500 miles
31,500 miles on veggie
Ditched the Auto trans 4R100
6-speed Handrattla...
Clutch pedal
FASS pump
DP 80hp econo tune
Veggie oil undercoating and bedliner
Homemade veggie kit based on FN74
4" exhaust
DIY Tymar
tool box
rear springs
Shocks
275/75/16 BFG A/T's
203* T-stat
fuel pump
Water Pump
IDM
Dents
Rust
brakes
Front caliper
ball joints
all u-joints
2 fuses
more rust............
Spotty is offline
Old 12-31-2007, 08:07 PM   #4 (permalink)
utahbio.com
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 12-31-2007, 10:31 PM   #5 (permalink)
hheynow's Avatar
filter bags
1997 F-350 PSD RC LB 4WD E4OD - Plant Drive SVO kit
1984 Mercedes Euro 300D NA - Custom two-tank SVO
Using WVO and biodiesel since May 2006
hheynow is offline
Old 01-01-2008, 10:14 PM   #6 (permalink)
luckuslucas's Avatar
On the bus I'm using a pair of 30" Rosedale Model 8's in series with 70 and 35 micron absolute rating cartridges. They work great, because we can pressurize the filters with our collection pump, so gathering and filtering is all one process. Once we pump it on board, it goes through the filters and to the dewatering tanks, so we never have to touch it again. We were able to run about 500 gallons through at a time before we had to change the cartridges.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline
