Does anyone believe that enough drive time has been put into testing Canola as an alternative fuel?
I am about to buy a 1999 f250 diesel 7.3L and want to know more about this new age conversion kits.
Well, if you buy it straight off the shelf and dump it into your tank, I don't think it's cost effective,,,,,,
How ever if you get it free from the restaurants after they have used it for their fryer, then it's EXTREMELY cost efficient.....
Buying a kit, or building your own.... either way I know a guy who runs it, and has had no issues yet.....(Well, he did have a fuel pump issue I guess,,,,)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
I've been filtering and then pouring used canola oil into my front fuel tank. I put a piece of cordboard ove 1/2 of my radiator to get it to heat up quicker. Once the motor is warm I switch from rear tank (100% diesel) to front tank 100% used canola oil with no problems. No conversion kit, no heaters. I switch back to rear tank when I about 1/2 from home.
White, 1996, F250, XLT, 4x4, 7.3 PSD, Garrett Turbo, Supercab, 8' bed, home made goosneck hitch, 257,876+ miles, Rotella T synthetic 5w-40, Motorcraft filters, BG synthetic trans fluid, two Haynes 1405 transmission fluid coolers.
I have over 100k on WVO in my truck and 35k in wife's Excursion. One of the keys to success is adequately heating the VO. We see 180-200* VO before the engine in our trucks and never switch over until engine is HOT. Do yourself a favor and buy a DFA or Frybrid system and enjoy nearly-free fuel from then on. You WILL get your money back if ya drive much and buying a system means it will work 100% on the first 'try'.
There are other companies out there selling 'cheaper' 'kits'. I have seen them all and I promise - there is nothing to compare...
DFA or Frybrid (uses DFA's V3 module) are worth every penny when quality counts!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
Ok got a question....I'm just a guy that likes to cook. I sometimes deep fry with canola or vetable oil. If I filter it, can I then just poor it into my tank with the diesel and drive off. lets say a mixture of about 1 gallon of oil to 40 gallons of diesel??
Jim
2003 EXCURSION EDDIE B, 7.3 PS, 4" Magnaflow Turbo Back exhaust with International up-pipes. BD-Power X Monitor, AFE Stage 2 and Edge Evolution. 6.0L Trans Cooler. JVC DVD head unit with 6 Boston Pro series speakers, Rockford Fosgate 12" sub and amps. Oh ya, AC power for the Blender.
Jim
Excellant way to replace the lost lubricity of the ULSD fuel.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
That is how I got started with canola oil. I've put about 40 gallons of canola, and soyo oil threw the front tank of my truck so far. I just filter it then pour into the tank. No conversion, no tank heater, no nothing but just some card board in front of 1/2 of the radiator.
