Who did you notify about Home brewing - Diesel Forum - TheDieselStop.com
Old 04-19-2006, 01:39 PM   #1 (permalink)
Just like the subject line says, Who did you notify. Since I'm living in a neighborhood and planning to brew in my garage should I notify someone, like fire dept, police ect to keep me from being jolted out of bed in the middle of the night under suspension of making meth or some other drug? [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Early 99 F250 Crew Cab. South Texas Outfitters grill guard and bumper. Rhino linered bed covered by a SnugTop Snuglid. Homemade Tymar. Rockford/Fosgate speakers. Nitrogen filled tires and a quiet torque converter. 98 gal bed mounted aux tank. PIAA pencil beam lights. 5 oz of ceramic ballance beads in each tire. Smoooooth Otherwise quite stock.
Airplaneguy57 is offline
Old 04-19-2006, 01:46 PM   #2 (permalink)
Re: Who did you notify about Home brewing
Thats a good question and I thought about it when I started, but then I am still thinking about it!
National Fire code does come into play due to the methanol. I think it was like, 10 gallons max based on the flamability rating.
I will probably continue to think about who to contact...... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 04-19-2006, 02:03 PM   #3 (permalink)
I remember reading somewhere before getting started about notifying your local fire department and making hazardous waste signs and having a plan and all that stuff. I figured I wasn't going to open that can of worms.
96 F250,Dark Green,Long Bed,Ext cab,AT, Tool Box with Gas Tank,Don't know all them other fancy things to put here. Bought the truck to burn my homebrew biodiesel and to pull camper. Always wanted one like this.
Wesben is offline
Old 04-19-2006, 03:10 PM   #4 (permalink)
absolutely no one. I dont want ppl knowing what i'm doing. Just keep it all in my barn so no one really has a clue and keep my mouth shut. I figure when you start lettin ppl know is when you'll start getting incestigated as to why you arent paying road tax. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1995 F250 Xcab 5spd 4x4. TYMAR, 5" Mitre Cut STACKS, Skyjacker lift, 35" Mud terrains, powered by Home made Bio Diesel, Cobalt C2 gauges, DIY INJECTORS by www.DIY-Injectors.com , 6 position chip by Fat Kid Performance Diesel(sn: house22), intercooler on the way within the next few weeks...
Nitro454 is offline
Old 04-20-2006, 01:31 AM   #5 (permalink)
Don't store over 10 gallons of methanol (like someone already mentioned), other than that don't tell anyone or the hippies will start showing up with their hands (cans) out... [img]/ubbthreads/images/graemlins/wink.gif[/img]
No one needs to know except your friends,
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 04-20-2006, 07:52 AM   #6 (permalink)
My Photos: (6)
Someone here mentioned hazardous waste issues. What hazardous waste? Remember, there's a difference between a hazardous material (methanol, caustic) and hazardous waste. Its not a waste until you are ready to throw it out as unusable for its intended purpose. Our waste stream is NON-hazardous glycerin.
In most cases, hazardous chemicals in what are considered 'industrial quantities' means letting local officials know what you have on hand.
In most states (maybe all) we have a Tier Two Community Right to Know law that states we must disclose a list of the hazardous materials, quantities and where they are stored. All chemicals have reporting thresholds. I doubt seriously we are going to have enough KOH or NaOH to worry about. The methanol may be a different issue. The more hazardous the chemical, the less it takes to trigger reporting requirements. Makes sense though.
These are typically commercial issues. Hazardous chemical storage in a residential setting is a different can of worms. Its probably not even an issue.
Check with some local racers regarding storage of methanol in their garage. The gasoline for your lawn mower is more flammable than our methanol. And your kitchen already has some caustic of varying types.
To me, the issue is safety to the emergency responders. The firemen need to know if there is a hazardous chemical behind door number one, two or three. This is especially true if it is reactive with water.... like our caustic.
I think talking to your local racers who use Methanol would be your best bet.
Todd T
ToddT is offline
Old 04-20-2006, 02:46 PM   #7 (permalink)
brahamfireman's Avatar
when the fire department shows up because your garage is on fire, tell them then. there realy isnt enough to make a huge problem. the cleaning supplys under your sink make for a worse fire then most would think.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 04-20-2006, 03:34 PM   #8 (permalink)
So let say I made an Appleseed system. How much methonal would I use for the process?
Old 04-20-2006, 03:50 PM   #9 (permalink)
depends on the size of the batch. I just buy my methanol is 55 gallon drums and throw it on the other side of the barn of the processor. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Nitro454 is offline
Old 04-23-2006, 09:29 AM   #10 (permalink)
hheynow's Avatar
storage considerations
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 04-24-2006, 10:57 PM   #11 (permalink)
h2odrx's Avatar
Man!!! oops!! i told the building inspector/fire inspector, and the other fireman/fire inspector, the fire chief, and the chief of police (F250 owner), even invited them over, (none came) the fire guys always come over when i burn yard waste to see whats on fire (lots of smoke) I love small town USA!!!! ok i also work for this small town so even the mayor knows, but i wanted them to know, so IF something would happen they would not be surprised, but i still say as long as you stay safe first they only need to know when they need to know!
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
