Old 03-29-2006, 01:51 PM   #1 (permalink)
Why does everyone use 22% Methanol??
So on my last two batches that were 40 gallons, I should have used almost 9 gallons of methanol. Well, I decided to go less. I used 5 and did everything else the exact same. Well, everything came out great and I nearly cut the metanol in half. I think we have been using too much and wasting it. I dont know if the quality of oil affects anything either. I have absolutely no water in mine and have been using a flat 3g/L of NaOH. No base of 5g/L at all. After everything is mixed in and had a chance to mix up, I will pull a small sample, mix it with alcohol, and throw in some indicator. If it comes out a light pink, i know it has fully reacted and I let it do its thing and go on as normal. I also tested this after I have completely washed and dried it, and no other glycerin settles out. Just something to think about for everyone out there. It has really cut down on cost and even makes washing easier since there is not as much excess methanol or lye in it.
1995 F250 Xcab 5spd 4x4. TYMAR, 5" Mitre Cut STACKS, Skyjacker lift, 35" Mud terrains, powered by Home made Bio Diesel, Cobalt C2 gauges, DIY INJECTORS by www.DIY-Injectors.com , 6 position chip by Fat Kid Performance Diesel(sn: house22), intercooler on the way within the next few weeks...
Nitro454 is offline
Old 03-29-2006, 02:30 PM   #2 (permalink)
Re: Why does everyone use 22% Methanol??
Thats only 12.5%. I would be concerned about complete reaction and reaction time.
I use 22% all the time and have excellent results. Tried more but did not see any benefit. As long as the correct heat is obtained prior to conversion, I think 22% is the least I will ever go.
The addition of a methanol recovery system would, for me, would be a better way to lower my Cost Per Gallon.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 03-29-2006, 03:46 PM   #3 (permalink)
I've read that under ideal conditions (not possible in the real world), the biodiesel reaction would use 15% methanol by volume. 20% is the minumum recommendation with 22% as the best.
With your 12.5% methanol, you can expect leftover FFA's and lower biodiesel product. That proof would be to have your fuel tested for quality.
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 03-30-2006, 04:00 AM   #4 (permalink)
My Photos: (33)
I use 20% with excellent results. (KOH)
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp 6V92TA, Eaton Roadranger 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff is offline
Old 03-30-2006, 06:08 AM   #5 (permalink)
I use about 20% methanol, but since I use it unwashed, the surplus methanol becomes part of the fuel and probably adds some heating value to it.
The mpg is almost identical to petro diesel so the methanol may have something to do with it.
My most recent mpg calculations are based on a trip to Florida and back using biodiesel one way and petro diesel for the return trip.
The mpg ranged from 8.5 to 9.5 for the approx 20,000 lb vehicle for either fuel.
Bjorn
The Blue Ridge Mountains of Virginia
1968 M49A2C military 2-1/2 ton 6x6 truck, modified. 1972 HIAB crane. Turbo charged Hercules multifuel engine. Dual/heated fuel tank for use of 100% biodiesel in cold weather w/o mixing.
cranetruck is offline
Old 04-01-2006, 07:32 AM   #6 (permalink)
methanol is your reactant and caustic is your catylist, by using less you may not be completly reacting,however by keeping processing temp. just under methanol vapor pressure and plenty circulating time,you may be o.k.. I like using alittle excess 20-22% to ensure complete reaction. [img]/ubbthreads/images/graemlins/cool.gif[/img]
grease_junky is offline
