Will B20 hurt anything - Diesel Forum - TheDieselStop.com
Old 04-23-2006, 05:56 PM   #1 (permalink)
I have a 05' and I am thinking of running biodiesel in it. Will B20 hurt any hoses or any other parts in the truck that it comes into contact with?
05', F250, 4X4, crew cab, Flumoto valve, 2 1/2" leveling kit up front, 4" block in rear, 60 gallon aux. fuel tank / toolbox in bed. BFG 285\70\17 tires Rancho 5000 shocks. Firestone air bags.
tpace is offline
Old 04-23-2006, 06:00 PM   #2 (permalink)
Re: Will B20 hurt anything
If by chance you have a problem nd have to take it to the dealer and they find B20 in there, they might call the fuel the problem. As far as any problems, as long as it is quality Bio, all should be good. Check it before you buy it. Make sure it is nice and clear and not cloudy or has floating particles in it.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- BB Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 04-23-2006, 10:35 PM   #3 (permalink)
hheynow's Avatar
It MAY void your warrenty . Ford's recommendations are a maximum of B-5. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 04-25-2006, 04:17 PM   #4 (permalink)
Late model vehicles (like yours) have more robust fuel components and should safely handle B20. I've run some pretty high concentrations of BioDiesel in my '03 (around B70)with no apparent ill effects. Others on this forum regularly run B-100 with no problems.
As noted above, Ford (and International) recommends a maximum of B5. That does not mean that running B20 will void your warranty. If you have an engine problem attributable to the fuel. The warranty will not cover it. Guess what happens if you are running pure dino and you have a warranty issue attributable to the fuel? Yep, same thing. The manufacturer is responsible for material and workmanship of the vehicle. Since they do not make the fuel, that's between you and the fuel supplier.
Buy good quality bioDiesel and you should be just fine.
2003 F-250 4X4 Lariat Crew Cab 156" WB, Arizona Beige over Black, 7.3 PSD,Superchips 1705 "tow safe", auto, 3.73 limited slip, X-Monitor, ARE hard tonneau cover, Line-X bed liner, Ford splash guards, vent visors, hood wind deflector, 50 gal Transfer Flow in-bed tank, Powerslot cryo rotors (front) with Hawk LTS pads, Ford AIS with fender sleeve, V3 Back-up Camera, Marinco mod.
kc_maverick is offline
