WMO filtering is this enough? - Diesel Forum - TheDieselStop.com
Old 01-08-2009, 09:25 PM   #1 (permalink)
Send a message via AIM to rockets10510
the set up i have filters the oil down to 2 micros. there are 3 different filters. the first filter is a 25 micron house water filter, the second is a 5 micron house water filter and the third is a wix 2 micron fuel filter. is this enough? another question would a cenerfuuge be a good investment as far as filtering wmo for fuel use? or is filtering it down to 2 microns good enough?
thanks anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 01-09-2009, 09:52 AM   #2 (permalink)
2 microns seems enough to me. From what I remember amsoil says the most damage happens a bit higher up on the micron scale there as in terms of wear and tear on bearings. The amsoil super duper bypass filter deal does filter to .1 micron though. Or so it says...
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 01-11-2009, 01:07 AM   #3 (permalink)
My Photos: (6)
Whether filtering WMO or WVO, remember that a 2 micron nominal filter only gets the majority of the particles larger than that size. It still lets a few larger particles through, just not very many. To truly filter to 2 micron, I strongly suggest running it through three or four times.
ToddT is offline
Old 01-14-2009, 07:04 AM   #4 (permalink)
2 microns fine since the factory filter is only 10. But why 3 filters ? I use a baldwin bf1212 & give it a couple of hours to circulate.
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
Old 01-14-2009, 10:41 AM   #5 (permalink)
what micron is that filter. can you send me a pic of your set up?
anthony
Parts Replaced:
Parts Replaced
