WMO Info - Page 2 - Diesel Forum - TheDieselStop.com
Old 06-05-2008, 02:57 PM   #16 (permalink)
JohnnyReb's Avatar
Originally Posted by kneescraper View Post
What is K-1 kerosene? How much is it compared to diesel?
Basically, its clean, clear, thin diesel.
www.coleman.com/coleman/msds/kerosene.pdf
It's running about $3.39 to 3.79 a gallon in Squanderville.
1981 MB 240D
JohnnyReb is offline
Old 06-05-2008, 04:04 PM   #17 (permalink)
06Clone's Avatar
My Photos: (5)
Just a term based on #1 fuel oil which is kerosene.
JP8 is its avaition cousin which is more finely refined and has a higher TU rating.
# 2 Fuel Oil is Diesel
# 3 Fuel oil is not made any more but is much like 10w motor oil.
# 4 Fuel Oil is Crude oil - what the old big ships like the Qween Mary ran.
06Clone is offline
Old 06-05-2008, 09:43 PM   #18 (permalink)
The numbers go up to 8 or so as per an engineering book. Meaning #8 takes high heat just to get it to ignite
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 06-06-2008, 09:24 AM   #19 (permalink)
LunaTech's Avatar
Originally Posted by JohnnyReb View Post
I mixed up my first batch yesterday.
My test diesel measured .84 on the hydrometer.
My K-1 Kerosene measured .80 on the hydrometer.
My WMO (mostly aeroshell w100) measured .90 on the hydrometer.
Mixing at about 33% K-1 and 66% WMO resulted in a SG of .85.
Please keep us updated on how it runs. Do you see any potential problems using this instead of diesel or are you going to add diesel before running in your vehicle. Thanks for the info and research.
1994 F350 IDI with factory Turbo, crew cab long bed with dual tanks
LunaTech is offline
Old 06-07-2008, 11:59 PM   #20 (permalink)
LunaTech's Avatar
Any news on the K-1 usage yet?
LunaTech is offline
Old 06-08-2008, 10:32 AM   #21 (permalink)
JohnnyReb's Avatar
I bought another 25 gallons Friday. I found a place that has clear K-1, no red dye. I have 12 gallons premixed (33%K-1/66%wmo) and will fill up tomorrow. I have only had the 240D for 2 weeks and it had some things to fix but its done now. I'll drain the tank, clean the fuel screen, and replace the pre-filter before I fill up.
1981 MB 240D
Old 06-08-2008, 12:12 PM   #22 (permalink)
you have just effectively cut your fuel bill by 66%. Sound like a winner
jski55 is offline
Old 06-08-2008, 12:14 PM   #23 (permalink)
K-1 has a quicker burn vs wmo. I didnt get the mileage of even #2 if i remember correctly.
jski55 is offline
Old 06-09-2008, 10:46 PM   #24 (permalink)
LunaTech's Avatar
Well I'm at a 70% blend and running GREAT!! Damn it feels good every time I start her up to think my fuel cost for this tank averages $1.42/gallon.
LunaTech is offline
Old 06-10-2008, 04:53 PM   #25 (permalink)
skunk's Avatar
jonny reb-
how do you like your 240 D? a friend of mine has one stiing around and hes going to give it to me for free! he has to many other projects to bother with it. what kind of MPG are you getting? what the engine size?
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
Old 06-11-2008, 12:53 PM   #26 (permalink)
06Clone's Avatar
My Photos: (5)
A lot of the 240D's (2.4L) got motor replacements at 250k or so mi and one trick was to save $1,500 and put in a bolt up 220D (2.2L) refirb. My old 220D got 42 highway and 30 city.
I was sucking off 50 more gallons of WMO from a friends shop and he told me that his old oil is about 60% Mobile 1 synthetic and 20% ATF and 5% or so hydro and brake fluids. He said all the newer mercedes he services use Mobil1 only. I think I'll double the amount of Xylene I've been using (to 4oz per 10 gal) to help break down the polymers.
06Clone is offline
Old 06-11-2008, 01:33 PM   #27 (permalink)
JohnnyReb's Avatar
Originally Posted by skunk View Post
jonny reb-
I really like it. Its a 2.4L engine (67hp). My best mileage so far was 32 mpg on the highway with ac off.
100 miles on the blend now. The only difference is the exhaust smell, it smells like the hangar! LOL! I am going to mix the next batch thicker (.87).
1981 MB 240D
Old 06-11-2008, 02:42 PM   #28 (permalink)
milner351's Avatar
My Photos: (5)
Wmo
Hey guys - long time - been busy with too many other projects.... in the middle of a kitchen remodel now... yuck.
We've also taken the diesel benz plunge - we picked up a high mile '95 D300 diesel with a few blemishes for a good deal - and I hope I can learn about that thing like I did here on my '97 powerstroke.
I have a waste oil furnace in my shop - so I already have an ample supply.
For the first 10 gallons I ran mixed at less than 50/50 in my powerstroke - I ran the furnace pump and filters to fill 5 gallon fuel cans --- it took forever, so I need to come up with another pump.
I'm also thinking about running more waste transmission fluid to help reduce the viscosity of the mix - I've heard that some guys run 100%WATF with good results.
What are good pumps to use -- thanks for the filter information above - can't loose with a Lowes water filter as a first stage!
Does PCV pipe work OK with WMO??
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 06-11-2008, 02:55 PM   #29 (permalink)
jstrauss's Avatar
Where does one obtain such a hydrometer? Is this the same thing we used to test battery acid with about 30 years ago?
1991 F150 SC 4x4 7.5L/ZF5
1991 SAE Bronco 4.6L/4R70W
2002 F350 CC DRW 7.3L/ZF6
2005 Escape 2.3L/CD4E
jstrauss is offline
Old 06-11-2008, 07:58 PM   #30 (permalink)
Different than the battery ones.
got mine here:
www.avogadroslabsupply.com you need the 0.850 to 0.090 one
jski55 is offline
