Re: WVO a few questions...
OK, as for fuel pump - stock pump is regulated to 54-58 psi, and will produce over 100psi for atleast a short period of time.
I've been abusing a factory replacement pump from O-Rielly's w/VO for over 30,000 miles. My pump is kinda mid-system, so it gets warm to HOT VO all the time. I have starved it (plugged filter), pumped cold sludge thru it, and run it for 10 hours straight at 70 psi prolly 150 deg oil at the pump.
It cost $159 and has a warranty. At the time, the other options were almost $300 and had no warranty.
There is only 1 fuel pump. There is a high pres. oil pump that supplies power to the injectors...
The stock fuel lines are all standard stuff. I spliced into stock lines to heads using compression couplings.
I think $300 is low (about 1/3 low) but maybe you'll pull it off by having more stuff laying around than me! (I got alot of STUFF laying around)
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
