WVO plus #2 Diesel - Diesel Forum - TheDieselStop.com
Old 03-18-2005, 01:21 PM   #1 (permalink)
WVO plus #2 Diesel
Can filter 20% WVO be mixed with 80% #2 diesel with out haveing problems? Or do you have to process it before mixing it?
2001 F250, Extended Cab, 4x4, OilGuard Bypass Filter, Ford AIS, Fleetguard Coolant Filter, 305/50 20 Tires
ford109 is offline
Old 03-18-2005, 02:56 PM   #2 (permalink)
Re: WVO plus #2 Diesel
yes just as long as it is filtered real good no problem I haven't been able to yet but I have heard some people say they are running up to 80% wvo it just has not been warm enough yet for me [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
Old 03-18-2005, 03:30 PM   #3 (permalink)
My Photos: (5)
I run 50/50 no problem and have gone up to 75/25 still no problem. I did add a in line filter before the pump but other than that no change to the stock fuel system.
2000 F350 SC 4X4 LB XLT 3.73LS DP-Tuner (Stock, 60Tow, 80Econo, 120 Race), ATS turbo housing W/Wicked Wheel, Banks BHA, DIY CCV re-rout, 203* T-stat, Sonnax/Tricum mod, DIY Tymar intake, Frantz Bypass Oil Filter, Autometer 4 Pillar Mount, Jeg's 4" Turbo Back Exhaust, SUVlights harness, Sylvania Silverstar 9007, 45 Gallon Excursion fuel tank, 26 gallon heated WVO tank, Lariat Wheels, BFG A/T 285/75/16's, Snugtop extra vision and Powered by Vegetable Oil!!!
90K miles on WVO and counting
socaps
JoJon is offline
Old 03-18-2005, 03:42 PM   #4 (permalink)
Banned
What is everyone filtering down too?
Scott
sagebel is offline
Old 03-19-2005, 11:14 PM   #5 (permalink)
I only filter to 10 microns , but the lower the better .
2001 F350 . Up to 85 % wvo . Heated fuel hose . Amber Goldenrod 10 micron filter before OEM filter.
DavidCNorwood is offline
Old 03-19-2005, 11:45 PM   #6 (permalink)
Banned
How are you guys mixing? Do you just get down to 1/4 tank, toss in some SVO and then top of with #2? I guess my question is do I have to blend the fuel outside of the truck?
Scott
sagebel is offline
Old 03-20-2005, 12:40 PM   #7 (permalink)
BlueMule's Avatar
My Photos: (12)
I never premix outside the truck. Usually I run the front tank empty and then put in 5 gal of #2,15 gallons of vwo on top of that and finish filling it with #2 For the rear I wait till its below ½ and then put in 5 gal #2 and 5 gal wvo.
BlueMule is offline
Old 03-20-2005, 02:15 PM   #8 (permalink)
I'm new to the WVO stuff, so please excuse my ignorance.
I have a '04 PSD and I plan to filter down WVO to 2 microns. If I mix the filtered WVO to half a tank of #2 diesel (or bio-diesel) will this mess with the injectors or anythink else in a stock setup?
Basically will 50/50 work or should I go heavier on the diesel side?
j
'04 Excursion, Post 9/03 Engine
wombo is offline
Old 03-20-2005, 03:31 PM   #9 (permalink)
It sounds like you have a 6 litre PSD, so I'd start out at 20%...you can always work up slowly, but why risk a problem starting all out with a high ratio?
'01 F350 CC 4x4 DRW, ISSPRO gauges, SCMT, Adj. 10k, 4" turbo back, Turbo Preluber, Gulf Coast bypass and trans filters..And a whole lotta other stuff.
copano is offline
Old 03-20-2005, 05:53 PM   #10 (permalink)
Sorry for my ignorance. I am new to the WVO, bio-fuels scene and want to make it work in my truck and possibly some farm equipment.
What I have read here are some people “washing” WVO then using it 100% in their vehicles. Others are simply filtering WVO and then blending it with #2 diesel?
If I go to a mom & pop’s Chinese restaurant or to a friend’s deep fryer get their used veg. oil, filter it down below the factory fuel filter micron specs, blend it with some #2 and I can burn it in my truck? Can I do all this without setting up a washer, etc?
I appreciate any info.
Tim
'05 F350 4x4, 3.73 LS,Super Cab shorty SRW, 6.0L w/T-shift
Med. Flint interior, <font color="red"> Bright Red exterior </font>, lariat luxury. Ordered: 1/15/05 Built 2/16/05 in driveway 3/21/05 ...LOVE THIS ONE!!
LEMON- '04/'04 True blue,F350 Lariat super cab shorty, 3.73LS 4x4, 6.0L w/Torq Shift, 11/03/2003 build, 11/19/2003 drove home! bone stock
DSB refund issued 2-23-05!
powerstroke_dies is offline
Old 03-20-2005, 06:10 PM   #11 (permalink)
My Photos: (5)
I've run 50/50 with no problem, but I think the key to it is mixing. When I fill up I have 17 gallons of WVO in 5 gallon jugs, I use the jug with the 2 gallons in it to start the mixing in. Yes it is a bit of a pain but I only have to do it about every other week. I have poured unmixed WVO in the tank, you can tell it goes straight to the bottom of the tank without mixing, the fuel pump gets a little louder. On the safe side I think it's best to add unmixed WVO after a good drive with a warm engine. I filter down to 2 microns before it goes into the tank.
socaps
JoJon is offline
Old 03-20-2005, 08:40 PM   #12 (permalink)
If just filtering the WVO and mixing it with #2 works, why are people putting all the time and energy into making bio-diesel?
Am I missing something here?
j
wombo is offline
Old 03-20-2005, 11:10 PM   #13 (permalink)
Banned
Bio does better at cooler temperatures than SVO. If you live where it gets cold, you may not be able to blend at all in the winter.
JoJon: What filter are you using to get down to 2 microns. I found a 5 micron paper element and anything lower is glass which is a bit spendy it you ask me.
Scott
sagebel is offline
Old 03-20-2005, 11:10 PM   #14 (permalink)
j
WVO typically needs HEAT to be run straight. Even mixing with #2 diesel, I personally get nervous over about 20% oil to fuel. Until we get a few more trucks with 100,000 miles on a fairly straight diet of WVO, im just skiddish.
Bio-Diesel on the other hand has quite a history of being safe, and lots of backing from both grassroots and commercial ventures. Lots more research into engine wear and the like. Bio-diesel is also not as cold sensitive as regular WVO.
At this point, its preference. I personally prefer Bio-D, but if I can rig my truck up with the FN-74 vegistroke style system, I might be tempted to run straight oil [img]/ubbthreads/images/graemlins/wink.gif[/img]
Ford_Forgotton is offline
Old 03-21-2005, 11:27 AM   #15 (permalink)
Two things:
1) When you say HEAT, are you talking about a chemical addititve?, or temperature?
2) With a 50/50 mix what temperature range are we talking about? (I live in San Diego, CA)
I filled a mayo jar with a 50/50 mix and stuck it in the freezer. No gel! [img]/ubbthreads/images/graemlins/smile.gif[/img] This seems too simple. Is there something else that I'm missing?
j
wombo is offline
