Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 08-19-2007, 10:35 PM   #1 (permalink)
wvo/rug/wmo
Hi All, new to this section, just finished repairs on f250 6.9 1985 purchased about a couple of months ago, ran the engine on 95/5 wvo/rug yesterday for approx 30 min. it ran great. I was surprised to say the least after all I had to do to get the engine running. (repaired cracked block at block heater, replaced starter solonoid, replaced all injector o rings, some several times since this is my first diesel experience, replace glow plugs, 7 out of 8 bad, bypassed the controller with a manual switch. now I read about someone using wmo (waste motor oil?)
I have several hundred gallons of used oil from air compressors, it seems to be about 20wt and extremely clean, have been using this in a heating stove I made last year. Can anyone give me info on all of this, mixture, ration, filtering etc.
thanks in advance
Bob
scooterbob is offline
Old 08-20-2007, 12:04 AM   #2 (permalink)
Spencnaz's Avatar
My Photos: (14)
Re: wvo/rug/wmo
30 minutes is nothing. Problems with WVO/RUG can take about a thousand miles to show up.
I'm not a fan of using WMO in engines, with the issues of dissolved metals going through the injectors to emissions due to burning oil in the first place turned me off right there.
With all the work you've put into getting your 6.9 up and running, I'd be reticent to run that through your engine.
It's your decision, but I heartily recommend biodiesel.
The POWERSMOKE
1986 F250 4x4 XLT Lariat Explorer, 6.9 with Hypermax Turbo and cowl induction.
221k miles and climbing, C6 Transmission. Gear Vendors. Dual tanks with 50 gallon tank added to bed, locking canopy. Dana 50 TTB with Ford 10.25 rear and 3.55:1 ratios. Running B100 with no ill effects. Homebrew BioD. 80 gallon biodiesel processor with custom machined vacuum venturi
1973 Dodge Monaco aka 'Elwood', 64K original miles, Dodge steel cop rims with dog-dishes. 400 B-block with single exhaust, due for dual exhaust. Up for sale.
Other wheeled 'secret weapons' in the works.
Spencnaz is offline
Old 08-20-2007, 01:36 AM   #3 (permalink)
Send a message via AIM to VD350
Re: wvo/rug/wmo
It will run well at that mix as I said. Add some fuel lines to the system so it helps get it hot before injection. When I ran UMO I dumped at most 5 gal per tank. At under 5 gallons smoke isnt as noticeable and people dont think your rigg needs a new ring job [img]/ubbthreads/images/graemlins/wink.gif[/img]. I was always hesitant at mixing anything over 5 gallons anyway
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-20-2007, 01:33 PM   #4 (permalink)
skunk's Avatar
Re: wvo/rug/wmo
i just changed the oil in my truck. i filtered it and put it in my vo tank and it burns great. ive been blending the two ever since ive been driving diesels. no harm done yet.
old smokey - 86 Ford F250 420ci Navistar IDI non-turbo diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, no muffler with 3" pipe, class 31 heavy duty tractor truck batterys, lots of real gauges, working on full work truck set up... runing waist oils with far from stock fuel set up...big red - 86 Ford F350, 4 door crew cab, long box, 444ci Navistar IDI non-turbo diesel, 2wd dana 70 dually rear, gears?, c-6 w/coolers, waist oil system soon... a real work horse...88 suburban, heavy half-ton, 6.2 non-turbo diesel, 4x4, 10 bolt front, 10 bolt rear w/ limited slip, 700r4, heavy duty bumper with winch, true dual exhaust. waist oil system is on the way... currently mixing fuels..
skunk is offline
Old 08-23-2007, 03:28 PM   #5 (permalink)
Re: wvo/rug/wmo
I have been running used trans fluid at almost 75-100% for 10000 miles now and no issues whatsoever other than it smokes a little bit here and there. Swap back to diesel just to make sure no other reason for the smoke then back to trans fluid.
2000 F250 Supercab,4" turbo back,203* stat,homemade tymar,full lunar gauges,BTS, D-P 4 pos High Idle,tow,econo,140. 305,000 miles and still runs strong. Now H2E. 08 mirrors. stage 1 singles.
zx800x is offline
Old 08-24-2007, 12:48 PM   #6 (permalink)
Re: wvo/rug/wmo
[/ QUOTE ] how many miles on any one vehicle on umo??? i use it also--but maybe you have more miles results----
94_turbo is offline
Old 08-24-2007, 01:32 PM   #7 (permalink)
skunk's Avatar
Re: wvo/rug/wmo
well i been around diesels sence i was a kid and it was allways comon pratice around the older guys to filter umo after an oil change and pour it into the tank. i dont know how many miles on one truck... i have only had my current 9.6 for a year so its had 2 oil changes worth of umo into the wvo tank. i also had a chevy 6.2 and i did the same thing with that. but i dont have a constant supply of umo and never had i only use it after an oil change. when i was a kid all the older guys never put umo into the power strokes. there was only one around when i was growing up. but they said it was a strong truck but couldnt deal with umo atf or anything. the navistars will eat anything up if you de-water it and filter it.
skunk is offline
Old 09-17-2007, 10:47 AM   #8 (permalink)
Super_Dave's Avatar
Re: wvo/rug/wmo
I added UEO to my diesel tank for the first time two years ago. I accumulate the oil from oil changes in our cars, my E350, my racing motorcycles, and other equipment.
It's not a lot, but it's a nice suppliment. My personal experience is that my engine runs smoother. Might be from the extra lubrication in the fuel system, might be from the extra BTU's, I don't know.
Super Dave
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin front & rear springs, 203* Tstat, Evans NPG+, coolant filter, Ford Transmission Cure
2007 Buell XB12R Road Racer
Super_Dave is offline
