WVO sucker tank, what am I looking for? Air compressor tank ok? - Diesel Forum - TheDieselStop.com
Old 06-25-2008, 11:55 AM   #1 (permalink)
505live's Avatar
Local craigslist has a guy selling an old 60 gallon air compressor tank due to a blown motor. I've been considering building WVO sucker, but I am wondering what I need to be aware of in tank selection / fitting requirements. I know water pressure tanks and propane tanks are popular, just wondering if an air compressor tank would have a sufficiently large fitting to transport oil through.
Also, what do you (ya'll?) think a fair $$ offer would be?
Any feedback would be great, I may try to go have a look at it here in an hr or so.
Cheers
Nate
2003 E350 EXT 7.3L PSD, Bought September 2008 @76,000mi.
DP Tuner F5
Bilstein HD Shocks
Centramatic Wheel Balancers
Autometer Phantom Boost, Transmission Temp, and EGT gauges
Powertrax autolocking rear diff.
Scangauge II xgauge
Dahl 75 Pre-pump fuel filter/water separator
Modified Sinister Diesel fuel bowl delete and regulated return + post pump filtration.
Tow Mirrors
Spahl power remote door locks
Dieselsite Max AC Assist
Added cruise control
Sealed Beam to HID Headlight Conversion
Personal blog http://505live.com
505live is offline   Reply With Quote
Old 06-25-2008, 10:12 PM   #2 (permalink)
SignDoc's Avatar
An air compressor tank would work fine. If there is not a fitting on the bottom, a good welder can do one for you. I have a 120 gal. propane tank I'm going to use and the 2" fitting on bottom makes the whole tank look "wimpy", but it will suck out oil like a big dog... I would think anything from a 1" up would be big enough, yes size matters, smaller = slower. Just make sure it's on the "most bottom" part.
2007 LCF 4.5 liter V-6 PowerStroke (yes... 4.5 V-6)
White, Aerial Lift 70' working height, 24" lift kit (outriggers)
Oil Guard by-pass filter, pre-lube/post-lube pump (to be installed)
Engine hr meter, PTO hr meter, nitrogen filled tires
SignDoc is offline   Reply With Quote
