Old 10-01-2007, 05:30 PM   #1 (permalink)
WVO tank sending unit
Well , my filter station is almost done and I've started gathering oil , so I'm starting to order my WVO conversion parts . I seem to remember someone suggesting a replacement fuel sending unit and I certainly don't want to deal with this after the tank is installed . Did I dream this , or is it that I just can't find it in the archives ?
Thanks for all the help so far !
93 F250 Super Cab 4x4 E4od 231,000 mi
Tommc56 is offline
Old 10-01-2007, 09:05 PM   #2 (permalink)
Send a message via AIM to VD350
Re: WVO tank sending unit
The WVO puts more strain on your fuel pump so its a good idea to place another pump inline to make sure your stock one doesn't get over worked.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 10-01-2007, 09:14 PM   #3 (permalink)
Thanks , yes I had planned to do that ,but my question concerns the fuel gauge sending unit . Will the stock one hold up ?
Tommc56 is offline
Old 10-01-2007, 10:58 PM   #4 (permalink)
oh ok, I had to reread it, When you said fuel sending unit I thought you mean the fuel pump. Yes the stock one holds up fine. i have run WVO and Bio through my tanks and never had a problem, they are just slow to respond which is the factory "Feature"
www.Fordemblem.com
VD350 is offline
Old 10-02-2007, 08:03 AM   #5 (permalink)
Thanks again , since you brought up the fuel pump... I plan to use a seperate pump to supply WVO and use check valves to eliminate switching . Where would you mount the new pump and could I tie the original pump to the tank switch to shut it off when I switch over ?
Tommc56 is offline
Old 10-02-2007, 10:07 AM   #6 (permalink)
in front of your tanks is your fuel tank switch valve, it has a main line and an return line on it. When we did my buddy's '92 7.3l we bought the $47 pump at napa, followed the line, cut it and installed the pump onto the frame rails.
www.Fordemblem.com
VD350 is offline
Old 10-02-2007, 02:19 PM   #7 (permalink)
My thought was that I would place it in the engine compartment at the end of my HIH fuel line and direct couple it to my WVO filter . The biggest concern I have is how well it will prime . Has anyone used any sort of quick connect provision for priming in their conversions ?
Tommc56 is offline
