You can successfully run a WVO fuel blend without the DSE magic potion. If you search my screen name here, you'll read that I've been doing so for over 3 years
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
I started blending in my truck this spring. Have about 2000 miles on it so far. Doing ok. My research has shown that the DS additive is not needed.
I use:
50% WVO
40% Diesel
10% gasoline
.02% trup
.02% acetone
Putting mothballs (naptha) and xylene into veggie oil is not biodiesel.
STARTED OUT WITH DSE MADE MY OWN BLEND WINTER AND SUMMER.
NEVER PUT GASOLINE IN ANY AMOUNT IN A DIESEL.
FILTRATION IS THE KEY,5 micron IS NOT ENOUGH FOUND OUT THE HARD WAY
BROKE THREE INJECTORS FROM DIRTY WVO. IDO NOT BUY FILTERS ANY MORE,USE CENTRIFUGE- OIL IS CLEANED TO 1/10 micron
GOOD LUCK.
GOOD LUCK.
Older Mercedes state right in the manual to add up to 25% gasoline for better cold weather starts. I've been know to run a little gasoline from time to time. Also nothing wrong with filtering if you do it right. These days my blends are WVO in summer and WMO in winter with diesel as the main and often only thinner. I use naptha if I have it up to 10 percent. Is it biodiesel? No. But it's cheaper, easier, less time consuming, requires less equipment, and is safer (no methanol around). I have no interest in biodiesel anymore.
DSE is a scam.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
Now over 4 years in the same two vehicles.
I tried it in my '05. I was getting lazy about making Bio, It ran fine for about a week then my 6.0 begin to have problems. By the time I got it to my mechanic the little "diesel secret" cost my $4000+ in repairs. This stuff is JUNK. Run like hell.
What exactly needed to be repaired and was it without a doubt related to the fuel?
