03 6.0 Low Pressure Oil Pump - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-28-2010, 04:38 PM Thread Starter
Pretty sure mine has gone out.I am gonna order the gear kit to rebuild it. Just wondering how big of a pain in the butt is it to change this and does it require any special tools? I turn the engine over and hold down the button in the filter housing and no oil at all comes into it.Its been suggested that this is the no crank problem.
I did re check the filter housing while cranking and after about 10 seconds the housing was only about and 1/8 th full and that happened all of a sudden at the end.
Restoration is offline
post #2 of 11 (permalink) Old 09-28-2010, 08:00 PM
You are correct in that you have to have Low Pressure oil before you can high High Pressure Oil. No High Pressure for the injectors, no start.
As for how hard it is to get to, not sure. I cannot remember if the front plate has to come off or not. Others will advise...
knightgang is offline
post #3 of 11 (permalink) Old 09-28-2010, 09:23 PM
Front cover does need to come off.
Mark
bismic is offline
post #4 of 11 (permalink) Old 09-29-2010, 11:05 AM
In that case, it is going to be a tedious job, the entire front end of the engine and all accessories in front of it need to come out. Time consuming.
post #5 of 11 (permalink) Old 09-29-2010, 02:12 PM Thread Starter
Is there a pressure gauge I could screw into the allen head hole to check the pressure before I tear all this apart and what should the pressure be?
post #6 of 11 (permalink) Old 09-29-2010, 04:02 PM
You shoudl be able to pick up an inexpensive maunual oil pressure gauge from an auto parts store and adapt it to the hole size for a pressure test.
You can have LP oil and have a failure in the HPOP system (could be as simple as an o-ring).
post #7 of 11 (permalink) Old 09-29-2010, 06:21 PM Thread Starter
yeah thats what Ive read up on. I'm in process of tearing down the LPOP to check the gears etc. With it not getting oil to the filter canister I'm gonna start there,plus its the cheapest fix if its the gears.Hope I'm right,I'm just throwing stuff at it to check it.
post #8 of 11 (permalink) Old 09-29-2010, 07:44 PM
TousleyParts's Avatar
Also be sure to check the front cover for damage. I have seen a few where the front covers were scored from the pump gears.
TousleyParts is offline
post #9 of 11 (permalink) Old 09-30-2010, 05:22 PM Thread Starter
I got the gears out and they seem to look fine.The o ring for the gear cover looks pretty flat but seemed to be tight against the case.There was some oil that looked burnt on the crankshaft end and was inside the harmonic balancer. Theres a lot of oil on the main case but that could have come from the HPOP leak I had but was fixed. Is the main pump just the gears on the crankshaft or is it inside the front cover?
Also can I put the new gears I have back in and the cover and then connect the batteries and spin it over to see if I have oil in the canister without hurting anything? Thanks guys
I did go recheck that front gear cover.There seems to me some minor scarring on that cover but its not bad to me.Shoould/could this be a problem and need replaced?
post #10 of 11 (permalink) Old 12-28-2010, 10:31 PM
I have the same problem and also have scorring on the inside of my cover, what was the verdict change it out or what?
StrokedMadness06 is offline
post #11 of 11 (permalink) Old 12-29-2010, 04:27 PM
You can remove the oil pressure sending unit and read your oil pressure.Also do not reuse the balancer bolts. The bolts are TTY.
lenzhotrod is offline
