03 6.0 rough idle, low compression, & tick noise - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-26-2013, 01:33 PM Thread Starter
cooper6.0's Avatar
need help! i have a 2003 f-250 6.0 that ran fine when i went to work and when i got off i went to start the truck and it ran rough almost like it was missing and there is a ticking noise to it but its not an exhaust leak. we took it home and did a voltage test on the ficm it had 48 volts with key on but when you crank it over it drops to 27 volts. it also threw a code for contribution/balance fault on cylinder six. i put a new ficm on it and a ford diesel tech said to put an injector in it so i did all that and had the truck hauled to the dealership to have the ficm flashed. when i went to get the truck they told me i needed a new motor because i hydro locked my motor and bent a connecting rod and was down 10% for compression in cylinder 6 & 8. i have the egr delete in it other than that its all stock. i didnt think it could hydro lock if it has the delete in? and the tick noise doesnt seem loud enough to be a bent connecting rod. i've drove the truck for 8000 miles with the egr delete on and the egr cooler wasnt clogged when i took it off. im taking it to another dealership to get looked at because i really doubt i need a new motor at 110,000 miles.
cooper6.0 is offline
post #2 of 2 (permalink) Old 08-28-2013, 02:26 PM
05_HARLEY_F250's Avatar
Had a #6 injector put in mine a few years back the dealership botched it and either dropped something in the cylinder or the new injector blew its guts into the cylinder. I ended up with the same ticking and loss of power and even some smoke, 2000 miles later I was having the engine rebuilt, something was in the cylinder and it passed through the valve screwing its seal to the head up, destroyed my turbo and I had bad scaring on the cylinder wall.
Between the two dealerships I did an oil change and noticed a very strong fuel smell in my oil, this tipped me off that something wasn't right.
Attachment 27401
I know this information isn't very helpful but I felt you should be aware of another possibility and always scope your cylinders when change injectors, you never know what you'll find.
Replaced or Updated: Radiator, thermostat, heater valve, degas cap, Stock Head gaskets, oil cooler, Harley Davidson windshield. ARP studs, STC, stand pipes, dummy plugs, Motorcraft max batteries, turbo oil supply & drain, Blue spring, Fuel/water separator drain plug, interior light LED conversion, Recon smoke LED tail lights, third brake light & mirror lights & added Big rig ice running board and Fire & ice tailgate strip. Other mods: Garrett powermax turbo with riff raff SP billet wheel & boots, Metal CAC tube w/cool it thermo tec aluminized coating, Harpoon, tailgate assist, Drilled/slotted rotors w/ceramic pads, Goodyear Wrangler Duratrac 275/65R20 & Gatorback belt, IPR Generation 2 EGR & up pipe delete. MBRP 5" turbo back SS straight, IPR coolant filter, Rotella ELC conversion Fumoto; oil drain, block drain x's 2, CCV drain. Electronics: PHP Gryphon/Eco, Atlas 40,80,Herc, Edge CTS insight w/EGT, Upfitter switch, high idle mod, JVC KW-NT700, Viper 5904 2-way.
05_HARLEY_F250 is offline
