03 Block Heater? - Diesel Forum - TheDieselStop.com
Old 08-07-2009, 07:27 PM   #1 (permalink)
06yz125's Avatar
03 Block Heater?
Does the 03 6.0 have a block heater, and if so, where can I find it?
Hate to be the bearer of bad new's BUT winter is coming
I just bought it,and have several more questions, however
I don't want to seem to ignorant all at once.
Thanks for any help
Gary
06yz125 is offline
Old 08-07-2009, 07:55 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
Welcome.Look around the passenger side tow hook or on the backside of the bumper.It should be there maybe ziptied somewhere.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 08-07-2009, 08:10 PM   #3 (permalink)
They all have the block heater. Some trucks did not come with the cord, some did (depended on where the truck was purchased - ie geographical location).
Mark
bismic is offline
Old 08-07-2009, 08:29 PM   #4 (permalink)
rock_doctor's Avatar
All 03s have the heater and cord. Around 2005 they decided to leave off the cord to save a buck, so MY 2005 and newer will not have the cord unless you are in a "cold region"...
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 08-07-2009, 08:37 PM   #5 (permalink)
Didn't know that - thanks!
Mark
bismic is offline
Old 08-07-2009, 09:54 PM   #6 (permalink)
06yz125's Avatar
Thank You
I crawled around under there with a flashlight and found it.
Now for the next dumb question
Is the oil filter on top of the motor?
And if it is, what is that smaller cannister beside it
that looks similar?
Ain't I a dumba**
Gary
06yz125 is offline
Old 08-07-2009, 10:17 PM   #7 (permalink)
Thats the secondary fuel filter , you will LOVE where the primary fuel filter is !
Stock 03 250 6.0 SD 2door 4x4 p/u
6.0 June 03 Build Date
92,000 miles
E-017 flash
5" Tail Pipe +Muff Delete , otherwise Stock
AND
2000 f350 7.3 ccab 4x4 , nice BIG truck that lumbers right along. Only 100,000 miles on it.
24hrsparkey is offline
Old 08-07-2009, 10:28 PM   #8 (permalink)
06yz125's Avatar
So I guess that is the oil filter on top? Thats a good thing, Right?
This truck has 60K miles on it, do I need to find the "primary" filter?
Or just ignore it and wait for the consequences. <smile>
06yz125 is offline
Old 08-07-2009, 10:40 PM   #9 (permalink)
Its under the drivers frame rail , called the HFCM primary fuel filter.
Also , it contains the fuel/water drain out, requiring a 6mm new allen wrench , i think the HFCM takes a large 26mm ? socket.
92,000 miles
E-017 flash
AND
Old 08-07-2009, 11:01 PM   #10 (permalink)
06yz125's Avatar
Do you think this is something that needs doing soon?
The truck runs good now.
06yz125 is offline
Old 08-07-2009, 11:08 PM   #11 (permalink)
06yz125's Avatar
06yz125 is offline
Old 08-07-2009, 11:14 PM   #12 (permalink)
The oil filter is in the engine compartment - under the hood.
Change oil and filter - 5k to 7.5k miles
Change BOTH fuel filters at 10k-15k (DO NOT GO OVER THIS INTERVAL).
Injectors are very sensitive to low fuel pressure!
Mark
bismic is offline
Old 08-07-2009, 11:16 PM   #13 (permalink)
Yes sir , the big one you refered to earlyer.
I like it , and its real easy to change .
92,000 miles
E-017 flash
AND
Old 08-07-2009, 11:36 PM   #14 (permalink)
06yz125's Avatar
Thanks for the help.
I'll start with changing the fluids and filters as you folks recommended.
It will give me a base line. Maybe I can get this truck to go to 100K.
06yz125 is offline
Old 08-07-2009, 11:42 PM   #15 (permalink)
06yz125's Avatar
Sorry, one more questin.
After changing fuel filters is there a problem with starting,
ie. do I have to purge the air from fuel lines?
06yz125 is offline
