Old 10-20-2009, 01:51 AM   #1 (permalink)
Question 03 Excursion with Fluid Leak
I own an 03 Excursion (6.0 L - Power Stroke) with 72,000 miles. I just noticed a fluid leak (very small spot) on the pavement towards the front of the vehicle. The oil is colorless. I also detected an unusual odor immediately after turning on the heater. I'm suspecting PS fluid. Any thoughts? I've never worked on this vehicle and greatly appreciate any suggestions or tips to diagnose this problem.
Bob
btricca is offline
Old 10-20-2009, 02:34 PM   #2 (permalink)
rock_doctor's Avatar
I would bet it is coolant. Check the radiator hose clamps. The bottom clamp has been known to leak.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 10-20-2009, 04:38 PM   #3 (permalink)
Also check your coolant recovery bottle CAP for leakage. Could be system over presurizing do to EGR cooler related problems Leak on drivers or passangers side. PS fluid should be redish and coolant does feel oily
2001 X Limited 4x4 PSD,F5 DP Tuner,Ford AIS intake, Magnaflow 4in.,Autometer GS 3pod pillar,BFG M/T KM 285x75x16,X-codes w/ blocks,6.0 cooler,eng.coolant filter,Hellwig sway-bar,RS9000X,Dark Satin Green,XM radio,Yakima MegaWarrior Rack. 1973 K5 Blazer 383stroker,TrickFlow alum.heads,Crower forged rods-roller lifter cam-roller rockers,Keith Black 10.5:1,Doug Thorley tri-y,MSD,ARP,Q-jet,on 1 ton axles 2003 Mastercraft X9
boomboom is offline
