03 F250 6.0 no start the first time - Diesel Forum - TheDieselStop.com
Old 10-15-2009, 07:35 PM   #1 (permalink)
F250crazy's Avatar
Went out today after work to leave turned key on waited for glow plug light to go out. Hit key and crank no start. Turned key on waited again for glow plug light off somewhat extended crank and started. Ran fine no issues all the way home. It was 49 degrees. Any advise would be appreciated. Thanks.
F250crazy is offline
Old 10-15-2009, 08:03 PM   #2 (permalink)
F250crazy's Avatar
Up coming problem?
Old 10-15-2009, 08:11 PM   #3 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Could be a leak in the HPOP system, if so it would only get worse. Let us know what it does tomorrow after sitting overnight.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 10-16-2009, 08:11 PM   #4 (permalink)
F250crazy's Avatar
Update. Started truck this morning. Turn key on waited and fired right up. It was 42 degrees. Seemed a little rough at start up and louder than normal engine noise. Got off work today no issues. Not sure what to do. Maybe it needs to get worse before I can pin it down.
Old 10-16-2009, 08:16 PM   #5 (permalink)
My Photos: (10)
All you can do is keep driving and listen for anything unusual....
Old 10-18-2009, 02:10 AM   #6 (permalink)
Sic4fitty's Avatar
Mine did the same thing. Some cold mornings it would be real hard to start, the rest of the day would be fine. Next morning it would start right up. It got to the point it would no longer start at all and it was the FICM. Got a used one off Ebay and the truck fired right up since then no problem. Just my .02
2006 F-450 Crew Cab Lariat DRW
125,000 miles
Egr Cooler Delete from ID
Hot start issue STC
Degas bottle cap
Sic4fitty is offline
Old 10-18-2009, 04:25 PM   #7 (permalink)
Be careful w/used ficm they do need to be programmed, you can just take it to ford (the used ficm) and they can flash it to your vin.
joshandlauri is offline
Old 10-19-2009, 06:58 PM   #8 (permalink)
F250crazy's Avatar
So far no more issues. I will keep you posted and thanks to all for the advise.
