03' turbo sound AFTER worked on at dealership - Diesel Forum - TheDieselStop.com
Old 02-08-2007, 03:08 AM   #1 (permalink)
darsey715's Avatar
alright so here's my deal. I want to know if any of you experience this same thing happening to your turbo. It just started happening to mine AFTER I had it at the dealership for a transmission flush, oil change, coolant system flush AND the controle module recall(which they coulnd't do because of the edge). (keep in mind I can always hear my turbo "whistling") After driving it for about 15mins and I come to a stop light or even a drive thru and the truck is in drive and has been stopped for at least 45sec to 1min it sounds like the turbo winds down to almost a complete stop. It sounds like a 7.3 or cummins or big rig as it idles with NO turbo whistle. As soon as I push the pedal down it easily winds back up and souns like it always has. I called the service manager and he told me this was normal and that the truck is "saving" the turbo and it was doing this because of the recall they did. I reminded him he didn't do the recall because of the chip and he said to bring it in. Is this normal? (my egt's are completely normal. 700 to 800 @ 75mph.)
darsey715 is offline
Old 02-08-2007, 07:43 AM   #2 (permalink)
ford_doctor's Avatar
Re: 03' turbo sound AFTER worked on at dealership
I love it when people make stupid statements like that. May I ask if the engine is doing this with your tune installed and are you SURE the modules were not reprogrammed? At idle, you shouldn't normally be hearing the turbo whining unless the idle is elevated and or the VGT is closed to raise back pressure during cold operation. Of course, if you have installed an aftermarket intake strainer and have opened up your exhaust, you will hear more noise from the turbo than a stock truck and it looks as though you have.
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is offline
Old 02-08-2007, 08:50 AM   #3 (permalink)
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img]unless it is extremely loud then they might not have removed the ficm relay to bring the oil pressure up to prelube the bearings in the turbo. thats the procedure i do everytime i replace one. yours maybe normal though. [img]/ubbthreads/images/graemlins/wink.gif[/img]
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
Old 02-08-2007, 03:12 PM   #4 (permalink)
darsey715's Avatar
The tune has been installed for a year or so and the turbo never made the noise. And the same guy told me they couldn't do the recall because of the edge and that they were gonna mark down that they did it so I could register the truck. thanks for your input.
Old 02-08-2007, 03:17 PM   #5 (permalink)
darsey715's Avatar
thanks for your help dieselmech, Im gonna ask him today or tomorrow. any more input or opinion on this would be appreciated guys. has anybody else noticed their truck do this? I find it odd it only does it after I get it back from the dealer. I'll post an update after I get back from the dealer.
Old 02-08-2007, 10:30 PM   #6 (permalink)
My new 03 does the same thing. As soon as you stop the truck, it always whines. Let it sit, it goes silent, Then has a nice rumbull to it, then you can hear it spool back up and whine. Noticed it today while I was filling up with fuel. Normal?
New truck
08 f-250 6.4 auto CC SB FX-4 stock
Sold
3/27/03 build F-350,CC,SB,DRW,6.0,auto,Black on Black,Blacked out bumpers/grill,285/75/16 Toyo A/T, 2" spacer, Alpine everything,Vector 1000w Inverter,16k Reese slider,Prodigy brake controler,MBRP cat back with muffler delete,Autometer luners on the A-pillar,Viper 5900,XM Radio
04 F-350 6.0,auto,supercab,shortbed, 8ft Fisher X-Blade, Hideaway Strobes, XM Radio,Alpine Head unit,X-codes, Edge Mini spring pack, Edge adjustable track bar,International helper springs 315/75/16 Toyo A/t,Prodigy brake controler,MBRP 3.5" downpipe,5"stacks
Last truck
sick, 1/7/03 build
2003 F-350 XLT supercab 6.0 powerstroke
4"lift 37 MT/R 372HP
http://community.webshots.com/user/traxx400-date
ipkyss is offline
Old 02-09-2007, 12:09 AM   #7 (permalink)
darsey715's Avatar
I went and talked to the service manager today. He said that because they did a transmission flush and coolant flush that my truck is running cooler so it's sending different signals to the turbo and the turbo is able to shut it self down to "save" itself. Dont know if he's blowing smoke up my ass or what but I asked for an oasis report (thx to this site I now know what this is) and the truck has the original turbo and injectors and egr and has not been in for any major replacement or malfunction. It's nice to read that your truck is doing the same thing, takes a little weight off my shoulders. Anybody have any other input or opinions? thanks.
Old 02-09-2007, 02:56 AM   #8 (permalink)
[img]/ubbthreads/images/graemlins/blush.gif[/img] sorry, i did'nt read your first post well enough. i thought you had had a turbo installed. being my birthday today & so much do do today i was exited. but it would be something to take into consideration someday. it is a normal!! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
dvtech is offline
Old 02-09-2007, 08:03 AM   #9 (permalink)
More BAD information.
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img]unless it is extremely loud then they might not have removed the FICM relay to bring the oil pressure up to prelube the bearings in the turbo. thats the procedure i do every time i replace one. yours maybe normal though. [img]/ubbthreads/images/graemlins/wink.gif[/img]
The reason for removing the FICM relay during module programing is to prevent damage to the #1 fuel injector and or injector driver in the FICM itself. For some reason or condition, the injector is energized during module recalibration. The relay we remove during the procedure shuts off the power feed that the FICM uses to power the injectors but not the module itself. That is why you are still able to reprogram the FICM.
I went and talked to the service manager today. He said that because they did a transmission flush and coolant flush that my truck is running cooler so it's sending different signals to the turbo and the turbo is able to shut it self down to "save" itself. Don't know if he's blowing smoke up my ass or what but I asked for an oasis report (thx to this site I now know what this is)
Another line of BS given to you by this service manager. If your engine were running cooler, that would get you closer to a cold engine idle strategy where the idle would be slightly elevated and the VGT would be closing to raise back pressure. The result of that would be the turbo spooling up at idle and you would have that whistle and air rushing sound. If your truck is running differently than before you brought it in, I suspect you more than the "royal flush."
Old 02-09-2007, 04:46 PM   #10 (permalink)
Sounds to me like the latest strategy for an '03. Mine will cycle the turbo vanes when at a warm idle with warm ambiant temps... With Cold ambiant temps the vanes close and idle speed will vary with current engine temp...
2005 Black Clearcoat F-350 SC Lariat DRW 6.0 TS 4x4 3.73's....AIRAID, SCT From Innovative, Recovering from Bed Plate Surgery and ARP implants... Came back from shop with some un-needed parts in the bed. Coolant filter
85 F-250 XLT 4x4 6.9 T-19 Plenty of fuel
1998 379 Ext. 3406E 18 speed Rockwell 46,000 rears/3.42's 6.2 M.P.G. @86,000 lbs.
2004 Black Clearcoat F-250 Lariat CCSB 4x4 5.4} yeah I know but it hasn't been in the shop...
modifiedoneton21 is offline
Old 02-09-2007, 05:26 PM   #11 (permalink)
darsey715's Avatar
what do you suggest I do?
Old 02-10-2007, 08:00 PM   #12 (permalink)
Send a message via ICQ to Davemcfarland
sound like they reflashed your truck, I bet if you check your strategy they re programmed it.
2003 f250 SD Arizona beige
engine build date is 12-23-02 and a Jan 03 truck.. sct tunes,daily driver.
2 bad injectors, blown headgasket,bad egr, bad ebpr,front brakes,ohh and a bent pushrod.
yeasu ft90... 305 70 16 nittos..
4 inch stainless all the way..
afe intake...
3 dogs
1 glock
107k as of 5-18-06
116k as of 7-9-06
118k as of 8-17-06
125k as of 6-27-07
Davemcfarland is offline
Old 02-11-2007, 12:38 AM   #13 (permalink)
darsey715's Avatar
what is a strategy? How do I check to see if they reprogrammed it?
Old 02-11-2007, 01:07 AM   #14 (permalink)
Do you have the Edge/Attitude or Edge Platinum ?
If you have the Edge/Attitude they can do a re-flash but you won`t get a complete flash,the trans won`t get the up-date.
Been there done that.
2 years ago I had the basic Edge/Att on and the tech did a re-flash,several months later I tried the Edge Evo for trans controls and it would not take.
The stratigy codes read recent engine up-dates,but the trans was old codes from 2 years earlier the last flash with no power programs.
I removed the edge and went back to the dealer and got a complete flash again then the EVO took.
If you have the Edge Platinum it would not take any flash at all.
The answer to how do you find out?
Find someone with a Xcal 2 it will read the stratigys even thru the Edge Att or Edge Plat,but you cannot program anything in with the Edge Plat installed.
Been there done that as well.
And it will not mess up any programs thats in someone else`s Xcal 2 if used for reading stratigys only.
Once you get the stratigy get with one of the sct dealers to get what up-dates you have you might be [img]/ubbthreads/images/graemlins/eek.gif[/img].
"Trade in"
2003 F-250,Lariat loaded and sweet except the 6.0.
Ordered 3/28/07 took delivery 6/7/07
2007 new body GMC Sierra SLT 3500 SRW long bed, Duramax/Allison,Black,loaded and even sweeter and more dependable.
toshiba is offline
