04 6.0 Cold Start? - Diesel Forum - TheDieselStop.com
Old 02-20-2009, 03:45 PM   #1 (permalink)
Send a message via Yahoo to CLARK11
04 6.0 Cold Start?
I have an 04 F-250 with the 6.0, It's having a hard time firing up in the mornings, any suggestions why ?
CLARK11 is offline
Old 02-20-2009, 05:50 PM   #2 (permalink)
OT
OT's Avatar
Welcome!
Can you better describe...hard time firing up in mornings? I assume it finally starts..then does it run ok & accel is ok or not ok?
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 02-20-2009, 07:39 PM   #3 (permalink)
Smiley1's Avatar
I had a bit of a hard time starting my truck up in the snow until I had the latest flash done. It would miss pretty bad. All is well now.
You might try changing your oil to a synthetic to help things.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 02-20-2009, 11:34 PM   #4 (permalink)
If your on the original batteries there probably shot. Try jump starting it to prove the problem.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 02-28-2009, 12:04 AM   #5 (permalink)
Check you glow plug. I had a friend with the same problem. He took it to a dealership, and they told him they had to change the injectors, I told him to check the G.P. first but he let them do it anyway, but they only changed out 4 (I dont know why). After they got done he still had the same problem, but by now it was warmer weather, so he let it go til winter. When the colder weather came back, so did the problem, so he took it somewhere else to have the other 4 injectors changed out and expecting about 2 grand in work. But when he went to pick it up, it was only 150 bucks or so for the Glow plug.
Duncan_n is offline
