04 6.0 Power Failure - Diesel Forum - TheDieselStop.com
Old 02-28-2009, 08:52 PM   #1 (permalink)
Send a message via Yahoo to CLARK11
recently my truck had complete power failure while driving, and has been starting intermitenly sometimes it wont even turn over and the battery indicator light comes on and off randomly. I was told to start by replacing the Batteries I did that and it doesnt seem to have fixed the problem the battery indicator light is still on, and i havent drivin it enough yet to see if it's still having power failure issues or not. I was curious if i should move on and try and replace the alternator next? and if anyone has had these same issues.
CLARK11 is offline
Old 03-04-2009, 07:55 PM   #2 (permalink)
Your problem can be caused by a bad ground. Make sure the ground wire is tight at both ends...battery side and truck side. If you have a multimeter you can also test the alternator by starting the truck and running the lights and A/C. Your battery voltage should read 13-14 volts while the truck is running.
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
KokDiezel is offline
