Re: 04 Emission Light
I've had 4 different causes of the Check Engine Light:
- EGR valve sticking
- Overfilled fuel tank (filling after the pump shuts off)
- Turbo failure
- Injector failure
The only one that cured itself was the overfilled fuel tank. After about 50 miles the light would come on. After another 100-150 miles the light would go off.
The others all set codes and needed a tech to repair.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
