04 F-250 6.0L Not Firing - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-24-2009, 12:29 AM Thread Starter
Ive got a guys 04 6.0 in my shed trying to see if we can find and issue before he has to head back home 365miles wednseday.
so far we know
Not 1 Passenger side injector is firing
has cylinder 8 contribution code had a 3 but it disapeared
so far
tested continuity from ficm plugs to injectors if pass side is 5,6,7,8 then 5-7 all passed but 2 of the prongs on number 8 had no continuity with either plug for the FICM as i beleive the 3rd plug is just power and pcm control?
found mouse nest under turbo but didnt look like they got into the wiring as far as we could see.
now running we unplugged each injector on the passenger side 1 by 1 and no change in rough idle.
watched exhaust with ir gun pass side never above 150 drivers 350+
turbo spools like crazy when driving but no power.
question is what could be the cause?
as far as i can tell from what my buddy who brought me the truck told me i beleive he was just driving down the road and blammy lost all power and running rough as hell
when plugging ficm back in it almost sounded like the poppet valves on pass side buzzed but drivers did not
2005 KR CC SB Auto 6.0L - "Sold"
1996
F250 Crew Cab LBox 5sp "Sold"
1972 Ford Gran Torino Fastback 351 Cobra Sold
Toy 1- 1996 - CCRB Auto - Intercooled, 10k Mod, E-Fuel
Toy 2- 1967 Ford Fairlane 2Dr Post factory non radio, non ac, manual brakes, manual steering. 80% restored working on interior Body and Paint done- 390FE stock oil eater, C6, Starshifter, Micky T Indy Style 60 Series on back. Originaly Black repainted Black
Work - 2012 F-150 XLT CCSB 5.0L -
96strokerlb is offline
post #2 of 4 (permalink) Old 11-24-2009, 07:15 PM
MikeL46's Avatar
My Photos: (14)
Harness issues?
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
post #3 of 4 (permalink) Old 11-24-2009, 07:36 PM
Originally Posted by MikeL46 View Post
Harness issues?
Mike
or try unplugging the ICP on the passenger side valve cover see if it runs. Does your scanner read the hpop pressure?
2004 F250 CC FX4 270k miles and counting
Innovatives programming, blue spring,
straight piped, Airaid intake,harpooned tank,
Egr delete, bullet proof oil cooler, arp studs, upgraded standpipes. Basically everything that can be done except the tranny
hooknline is offline
post #4 of 4 (permalink) Old 11-25-2009, 09:35 PM
Racer-X's Avatar
If you have ever seen how little wire chafing it takes to shut down a cylinder (the size of a pinhole) if you have a mouse nest I think you have your answer.
2005 Excursion - and I am not Racer X from Pasadena Texas even though this forum seems to confuse me with him. I wish the moderator would fix this issue!
Racer-X is offline
