04 long cranking when warm - Diesel Forum - TheDieselStop.com
Old 03-11-2009, 04:06 AM   #1 (permalink)
i have read on here about the problems with the 05 and newer having this problem is it likle to be the samething with my 04? the motor sounds like it is cranking over faster then just before it starts is slows down a bit? it hasnt not started on me yet but itsmaking me nervious any thoughs on this?
jph5413 is offline
Old 03-11-2009, 07:46 AM   #2 (permalink)
blackwaterstroker's Avatar
man don't get nervious...Most post are all neg. about the 6.0 I have 165k on my 6.0 and she runs like a dream...no starting problems...and all orig. parts. so I wouldn't worry about something that hasn't happend.
John Boy
2003 6.0 Powestroke Fx4, Lariat, Sunroof, Heated seats.
straight exhaust. (sounds like a jet taking off)
285/75/16 BFG all terrain.
165k miles and no problems!!!
ALSO
1995 F-250 2wd xl 7.3 Powerstroke 5spd.
330k miles and a straigh exhaust. Sold and missed dearly.
blackwaterstroker is offline
Old 03-11-2009, 07:55 AM   #3 (permalink)
RatherBNtheWoods's Avatar
Batteries in good shape?
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 03-11-2009, 11:26 AM   #4 (permalink)
How long is "long"? My 03 fires in about 3 to 4 secs. I had the OEM batteries on it until last month, and they were still cranking it strong (I figured 6yrs was pushing it though).
OMC
OMCUSNR is offline
Old 03-11-2009, 07:52 PM   #5 (permalink)
the batteries are in good shape i had them tested when i replaced my alt. it will crank for 7 -10 sec before it starts but only once the motor has been ran for a bit. i have 120k on the motor i just did the egr mod to it after it started leaking the motor runs great other than the long cranking
jph5413 is offline
Old 03-11-2009, 10:24 PM   #6 (permalink)
Is your oil level below the full mark on the stick? An overfull oil level will cause increased cranking time to build HP pump oil pressure when warm in my experiance. Its also been my experiance that not all of these dip sticks are created equal.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 03-12-2009, 01:30 AM   #7 (permalink)
i put 15 qt in it this time when i put it back toghether after the egr thing cause i bought the oil from ford, but normaly i do 4 gal of delo 400 maybe that has somthing to do will add some and see thanks for the suggestion
jph5413 is offline
Old 03-12-2009, 08:04 AM   #8 (permalink)
69cj's Avatar
4 gal, 16 qts, is too much!
69cj is offline
