05 6.0 VERY hard start cold - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 03-12-2011, 09:01 PM Thread Starter
Hi all. Its been a while since I have had to post here. My 05 F450, 134K miles, would not start after sitting about 7 hrs. I did replace the fuel pump and the short harness. It took a while to start but ran well that night going home. Now it is very hard to start either cold or, if it has been sitting during a work day. When it does start, I have to sit and feather the throttle til it warms up some. It will start if plugged in overnight but, runs rough till it warms up. I do all my filters with Motorcraft on a regular basis. In the past I have replaced...19 fuel injectors, Hi-pop, FICM, EGR cooler kit and OEM oil cooler, fuel pressure reg update kit. I do really like this truck and it does what I want and more. It has been over a year since the last problem, It is just hard to keep this up. What could be wrong now??? Your help and advise is always welcome.
Rich
2005 F 450,4WD crewcab Dually, 96 Gal heated aux fuel tank, air ride hitch, coolant filter. Ford fuel pressure regulator spring kit.
1992 Ford F450 flatbed car carrier w/wheel lift.
RPFAN3460 is offline
post #2 of 24 (permalink) Old 03-12-2011, 09:19 PM
Feedback Score: 2 reviews
Rich
Rich
19 injectors has to be some kind of record right, do you use Ford filters all around a must, how new are your batteries, are you running Syn oil maybe a 5w40 good, any centane boost in the fuel and 2 cycle oil in the fuel, Rev-X in the oil they say it works, max 5k on the oil because these injectors run in oil, low batteries take out the FICM???
Do you know what your fuel pressure, under 45lbs KILLS injectors
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #3 of 24 (permalink) Old 03-12-2011, 09:34 PM
paintingman's Avatar
Definitely check your fuel pressure it should not be less then 45lbs. and try some fuel additive i have been using this one it really helps with cold starts
AMSOIL Fuel Additives and Performance Improver
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #4 of 24 (permalink) Old 03-12-2011, 09:44 PM Thread Starter
Thanks for the quck replies,
Hope this helps...
2 new Optima batteries, ALWAYS use all Motorcraft filters, 5/w40 Rotella since I bought the truk 2 10K miles. Fuel psi was checked before and after reg upgrade, 38 and 64 after. I run C tain boost(I buy a case at a time.) Oil change between 4 and 5 K miles. I try so hard to keep the maint up because of all the issues. I almost want to go back to gas. This has to stop somewhere.
post #5 of 24 (permalink) Old 03-12-2011, 09:49 PM
Sounds like your doing all the right things and it's still hard to start?
ATS Intercooler
Aluminum degas tank
post #6 of 24 (permalink) Old 03-12-2011, 10:15 PM Thread Starter
It quit on me a few days ago, no warning, just would not start. I replaced thr fuel pump (OEM) and a wiring harness as the new pumps have 2 connections and the original has 3. As per the dealer, later 05 went to this 2 plug pump due to a problematic heater in the pump. If I do not plug it in overnight, its a bear to start. I guess its back to the dealer
post #7 of 24 (permalink) Old 03-13-2011, 10:24 AM
when it does start after sitting for an extended period ,does it have the brief classic puff of white smoke+unburned diesel smell???after maybe 3 start attempts along with higher than normal cranking speed???
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #8 of 24 (permalink) Old 03-13-2011, 03:50 PM Thread Starter
Smoke, seems dark but will check better. Fuel smell, yes. As for craking speed, hard to tell with 2 brand new batteries. Seems maybe faster. What bad news does that bring me??
Rich
post #9 of 24 (permalink) Old 03-13-2011, 04:43 PM
Rich...not all will be bad news...first we need codes to point us in the correct direction...from the sound it you either have a severe stiction problem or a bad glowplug relay or module...that would just be a guess at this point and only sheer speculation on my part...anyways post back with codes so the guys can help you get it going...i will ask...are you the original owner?19 fuel injectors is for lack of a better word is incredible...b
post #10 of 24 (permalink) Old 03-13-2011, 06:05 PM Thread Starter
I will get codes. I am the second owner, bought it with 10K miles. And yes...19 fuel injectors. I can't thank all of you enough.
Rich
post #11 of 24 (permalink) Old 03-13-2011, 06:21 PM
i almost hate to ask...does it have a steel fuel tank under the bed???...think delamination issues...b
Last edited by 03powerstrokeuser; 03-13-2011 at 06:24 PM. Reason: additional comment
post #12 of 24 (permalink) Old 03-13-2011, 08:39 PM
When was the upgraded regulator spring installed?
Whose injectors were installed (OEM, aftermarket)?
Mark
bismic is offline
post #13 of 24 (permalink) Old 03-13-2011, 10:41 PM Thread Starter
Plastic tank on the frame, aluminum in the bed. Srpring kit done last may, all injectors replaced under warranty with OEM by my dealer.
Rich
post #14 of 24 (permalink) Old 03-14-2011, 03:03 AM
This is just a long shot the 04 has a throttle plate your truck my be early 05 and have a active throttle it works with the EGR valve. I had nothing but problems with mine something electrical would tell it to close and chock air flow to the engine that's why i put the CFM elbow on at that time to remove the plate you can see it here it this link. The only way to see if you have one is to pull off the intercooler tube. This would have nothing to do with your injector problem though
http://dan.prxy.org/truck/6L_bible_h.../Page_038.html
ATS Intercooler
Aluminum degas tank
post #15 of 24 (permalink) Old 03-14-2011, 01:11 PM Thread Starter
Well, had my tech from the Ford dealer come by with scan tool and laptop. FICM voltage @ 32 and drops. Cam sensors, oil psi while cranking was good. So, now I will try the fix. Is there any info out there for the capacitors that have to be replaced as far as capacities and such?
Thanks to all who responded. I don't know what I would do without this site!!!
Rich
