'05 F250 4x4 ESOF won't work - Page 2 - Diesel Forum - TheDieselStop.com
Old 10-22-2009, 10:31 AM   #16 (permalink)
Regarding the defrost. It runs on the same vacuum supply as the hubs in the earlier models and when it looses vacuum it defaults to defrost as a safety issue. Plug the vacuum supply to the hubs to prevent loss of vacuum while in 4 wheel drive. If you repair the vacuum hubs the defrost will work right. Make sure you are getting vacuum all the way into the hub I have seen several times the line or lines are damaged and the hubs were blamed. The '06 and up use a cartridge style hub from ford only. just bought one. Much better design than the old one. Different wheel bearing to, just replaced one. Apparently the '08 up use the vacuum pump for ESOF only as the manual shift does not have one.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
Old 10-23-2009, 05:47 PM   #17 (permalink)
Vaccum and Defrost
Well, now that I have gon to Warn manual hubs anway, should I just then unplug the tube that is in the holder over the wheel in that small metal bracket and cap that off and see? Only an issue now when in 4wd (which is rarely) but would be comforting to have the problem resolved.
gcoutlaw is offline
Old 11-15-2009, 02:36 PM   #18 (permalink)
Tungsten's Avatar
Durantdiesel... did the transfer case motor fix the problem for you? My 2004 is doing the exact same thing but a tech that I took it to said that he believed the transfer case motor on mine was fine.
No 4WD related lights work on the dash at all. There is no power on either side of the 4WD related fuse in the fuse panel either.
~ No longer a Ford PSD owner. Got sick of throwing good money after bad. ~
Tungsten is offline
Old 11-10-2010, 04:43 PM   #19 (permalink)
Which fuse # is that??
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 11-11-2010, 07:56 AM   #20 (permalink)
Tungsten's Avatar
Man, that reply from me was last year... I'm surprised I was still subscribed to this thread.
I have no idea which fuse it was. Shortly after we got our ESOF system working again, the transmission started slipping real bad. This after we'd already sank $5K into it to have the turbo rebuilt, head studs, gaskets etc. and then another $2.5K into it because of injectors.
When the transmission started to go, we dumped that POS truck and never looked back. It'll be a pretty cold day in hell before I own another Navistar 6.0L Diesel anything.
Tungsten is offline
