'05 F350 Overheats - Diesel Forum - TheDieselStop.com
Old 03-02-2009, 09:59 PM   #1 (permalink)
'05 F350 Overheats
Hello all,
I am new here and hope someone can help me out. I just purchases an '05 F350. I thought I checked everything out really well before buying it but now I am having a problem. I was hauling a horse trailer up an incline with out any problems. I was going around 70 mph when all of a sudden I lost most of the power, the check engine light came on, and the engine started overheating. I talked to the dealer that sold this truck to me and he said it sounded like the thermostat. He said that the thermostat has a fail safe that shuts power off to the engine when it overheats and that I would just need to replace the thermostat. I have heard alot of bad things about this diesel engine but needed to upgrade so I took a chance. Does this sound like a possible quick fix or am I into an expensive fix?
Thanks for the help.
cjmair is offline
Old 03-02-2009, 11:56 PM   #2 (permalink)
redneck_rheino's Avatar
My Photos: (36)
Hope your under warrenty still. Is the degas bottle look like it has white residue all over it and the air box? Probably a blocked up oil cooler, mine overheated when that happened. Could be Head gaskets too.
*SOLD* 2005 F-350 XLT Supercab SWB PSD, Zoodad mod, Installed factory clearance lights and tailgate running light, line-x bed liner, sirius radio, GOS racing headlamp harness, Coolant Filter, Toyo M/T's 285 75r 18, platnum injection diesel catalyst system, 4 in straight exhaust, Blue FPR spring and 6.4 banjo bolts upgrade, delo 5w40 syn with hss, 2 stroke oil in the tank
Truck Pics
*SOLD* 2006 Ford Fusion SEL 3.0 V6 dark blue pearl
2011 Ford F-150 Supercrew XLT 4X4 6.5ft bed 3.5L ECOBOOST
2006 Chrysler Pacifica Touring AWD 3.5L V-6
redneck_rheino is offline
Old 03-03-2009, 10:24 AM   #3 (permalink)
I did not see any smoke so I am hoping it was not the head gasket. I understand that the oil cooler is not covered under a warranty either but that you may be able to bypass it if needed.
cjmair is offline
Old 03-03-2009, 12:48 PM   #4 (permalink)
69cj's Avatar
Oil cooler should be covered under the 5 year, 100,000 mile engine warranty.
69cj is offline
Old 03-03-2009, 01:31 PM   #5 (permalink)
BLOWINSMOKE99STROKE's Avatar
you dont live in Sarasota Fl do you? there was a truck on a dealer lot we looked at, and it had warped heads, and bad headgaskets, aswell as a bad egr system. Truck looked real nice and had an awesome chip, but the motor was toast.
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
Old 03-03-2009, 03:01 PM   #6 (permalink)
rock_doctor's Avatar
A white crust around the degas bottle will tell you you have bad gaskets, no crust and you probably are ok there.... You can change the thermostat yourself, just like you would on any engine just be sure to use the ford gold or zerex G05 antifreeze and distilled water to refill the rad. I would also take it back to the selling dealer and make sure it has the latest computer flash. Some of the trucks were having issues with the fan turning on too late or not at all. While it was overheating you should have heard the fan running (sounds like you are being passed by a jet plane - you will literally say to yourself "what the *ell is that"). If you did not hear the fan go on then that would be the starting point. It is electrically controlled by the computer, make sure the wire is still connected. Also...some of the trucks had bad dashes that would show an overheat but there really wasn't, this was in the 04's i think but if you have an job 1 05 it could be a possibility. Approach the dealer about this at the same time you ask about what software (flash) the truck has. good luck and don't panic.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 03-04-2009, 08:28 AM   #7 (permalink)
I heard the fan come on and do not see an white crust. I did find out some interesting stuff from a Ford dealer about the truck. Apparently the transmission has been repaired once and replaced once, the turbo has been overhauled, and the EGR valve has been replaced three times.
cjmair is offline
Old 03-04-2009, 12:21 PM   #8 (permalink)
Thanks for all of the help. I really appreciate the responses. I have one last question. Does any one know how I could get a full repair history on this truck? I called my local dealer and they indicated that they could only pull the last 60 days and only on their location.
Thanks.
cjmair is offline
Old 03-04-2009, 01:58 PM   #9 (permalink)
naw, any dealer can give you an oasis report which will tell you all warranty repairs done to the truck. They just look up your VIN. I would not worry about the egr replacements, the egr is an issue, i am on my 3rd myself. I am surprised about the trans the ts has been very stout. Did the truck have a snow plow mounted in it?
