05 INTERMITTENT BRAKE TROUBLE!? - Diesel Forum - TheDieselStop.com
Old 05-03-2005, 10:37 PM   #1 (permalink)
My dads 05 occasionally wont want to stop! The ABS light comes on and when you hit the brakes, they pulsate real bad like if you have ever had to run off the road and slam on brakes the ABS kick in and pulsate. This concerns me for his safety. Anyone having this problem?
2004 F-250 Lariat 6.0 4x4 CC Short Bed ,05 front end conversion, 05 flares ,4in. lift, 305/55/20 Nitto Terra Grapplers on 20x12 Weld Cheyennes, MBRP 3.5 DP 4 out to 6in. Silverline tip, SCT tuner, Quadzilla Monster intake KandN filter and camoed out!
RaulDog is offline
Old 05-03-2005, 10:46 PM   #2 (permalink)
Banned
Re: 05 INTERMITTENT BRAKE TROUBLE!?
Haven't seen it but I have to suggest getting in for repair now rather than asking if anyone else has seen it....
GrampyJim is offline
Old 05-04-2005, 02:35 PM   #3 (permalink)
My Photos: (5)
Havent had that concern, but I have noticed how when at a stand still, even on level ground it appears like the brakes lose grip for a .5 of a second and then repressurize or something cause the truck will surge forward but the rpms stay the same.
Anyone else?
2005 F-250 Lariat SuperDuty CrewCab 4x4, Dark Shadow Gry, 6.0L PSD W/TorqueShift Auto, Moonroof, Power Rear Sliding Window, and with every other option!
"If you want to kick the Tiger in his A_$_$, you better have a plan for dealing with his teeth" - Tom Clancy
"A law is valuable not because it is the law, but because there is right in which it was written."
"The best of all governments is that which teaches us to govern ourselves, for the goverment is us; we are the government, you and I."
http://community.webshots.com/user/deputy_sheriff
DeputySheriff is offline
Old 05-04-2005, 06:41 PM   #4 (permalink)
My 05 PSD F-350 FX4 Dually has had very similar brake problems except no abs light ever comes on. Mine is usually when towing and on the road for awhile when I first push the brake pedal it goes about an in. from the floor, seems like it has about 30 percent braking ability when this happens. If I pump the pedal a few times the pedal gets firmer and seems to stop better. I have complained to the dealer and they can't find anything wrong. Suggested maybe there is air in the system so they said they bled the system which did not cure it. I'm wondering if the master cylinder is bypassing internally or the ABS unit malfuntioning? Don't know a fix yet but it is definately a safety issue for sure. Keep us posted on your journey curious to know...
Katnew is offline
Old 05-04-2005, 06:48 PM   #5 (permalink)
My 05 does the same thing, sometimes when stopped the truck inches foward a few inches then I will apply more brake to make it stop.This is amazing how many new trucks have these same problems yet Ford will probably say the truck is operating within factory specifications...
-----Keep us posted on any further developments.
Katnew is offline
Old 05-05-2005, 12:04 AM   #6 (permalink)
joc
Mine does similar things, but no lights on. I have to stand on it at a stop. Almost hit a few cars at traffic lights. Pedal keeps getting closer to the floor. [img]/ubbthreads/images/graemlins/confused.gif[/img]
2005 Lariat F250 Crewcab 4x4 Loaded
joc is offline
Old 05-05-2005, 04:15 PM   #7 (permalink)
I would take it in. Sounds like air in the lines, IMO......
2005 F-250 CC SWB XLT-Sport 4x4 All White
Engine Built 01/04/05 in Indy
2005 Cadillac CTS-V
"He's dead now!" United States Marine Falluja, Iraq
American_Pride is offline
Old 05-05-2005, 06:39 PM   #8 (permalink)
I've seen trucks do this when brakes got hot.Not on fire hot but hot like when towing.It was caliper pistons sticking.After a minor cool down would be ok and dealer could not duplicate.But it was pistons sticking in front calipers.
ketchum is offline
Old 05-05-2005, 08:50 PM   #9 (permalink)
FMTRVT's Avatar
My Photos: (16)
Sounds like a bad sensor or tone wheel. You need to have a dealer check it out.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 05-05-2005, 08:51 PM   #10 (permalink)
FMTRVT's Avatar
My Photos: (16)
That sounds like a bad seal in the master cylinder, so you loose either the front or rear brakes.
Jack
FMTRVT is offline
Old 05-05-2005, 08:52 PM   #11 (permalink)
FMTRVT's Avatar
My Photos: (16)
Also can be brake fluid boil.
Jack
FMTRVT is offline
