05 overheat issue - Diesel Forum - TheDieselStop.com
Old 05-15-2005, 03:21 PM   #1 (permalink)
05 overheat issue
Folks,
Been awhile since I have been on here.
My friend has an '05 6.0/auto/4.10s, 4x4, drw, King Ranch with all the options including tow command. It was bought before the Tow Boss package was available, so no 4.30s. 12,000 miles. Anyway, he's towing a two car car hauler Denver to Moab today. 65 degrees, ~ 14,000lb traile weight (GCW of around 23). Whenever it pulls a big hill the coolant guage goes to the red, then the fans come on and then it drops back to normal. He says it has done this repeatly on most of this hills. Now these are steep grades, at 7-11 000' altitude, so I'm sure the truck is running WOT at about 45-50 mph up them. (The 7.3 would do this with only 8 k lb in tow). He is runnign in tow haul mode, and the truck is completely stock.
I know I read in the fall this was normal, is that correct? Is any damage occurring do to this? He isn't exceeding any limits of the truck but it is close to them.
ramv is offline
Old 05-15-2005, 06:36 PM   #2 (permalink)
Re: 05 overheat issue
My truck does the exact same thing, but I have yet to get a solid answer as to whether or not the temp is actually as high as the guage says. I read the same info as you, and to date I have had no problems from this. Maybe someone with more info can chime in?
2005 Harley Davidson F250
Black on Black, stock for now, just enjoying the smooth ride and problem free lifestyle for a while!
harley05 is offline
Old 05-15-2005, 06:50 PM   #3 (permalink)
NickBeek's Avatar
My '04 temp guage never moves once it reaches normal temp. I run in the foot hills of SC pulling a 9000# travel trailer. I have done so in 90 deree weather with the air on full blast. I would not think this is "normal". My guess (and it's only that) would be an air cavity in the cooling system, or a problem with the fan system, or a tranny issue. I would not accept it as is.
2006 2500 SLT Mineral Grey, 6 speed, 4x4, Thunder Road Package, MBRP Muffler + 6" dual Stacks, Fast Idle Enabled. Silencer Ring MIA, CFM+ intake horn, Smarty POD, SB Con OFe.
Traded:2004 F250CC FX4 XLT Long Bed Torque Shift, $5.00 AIC.
NickBeek is offline
Old 05-15-2005, 06:52 PM   #4 (permalink)
This is strictly an 05 issue as I understand.
harley05 is offline
Old 05-15-2005, 07:28 PM   #5 (permalink)
Thats what I have read too. And since the guage is just an idiot light, who's to say what temp it really is at (they calibrated the '05 different)
ramv is offline
Old 05-15-2005, 07:37 PM   #6 (permalink)
south_paw's Avatar
My Photos: (16)
Here's the TSB ..... Temperature Gauge Reads Hot, 05 F-Series:
Some trucks built before 12-10-04 may have a temp gauge reading at the top of the green normal band or into the red hot band, with normal coolant temperatures. If no overheat condition is present, the instrument cluster should be replaced. If there is a code in the engine computer for ECT over 240 degrees, or if coolant is being expelled from the degas bottle, do not replace the cluster. Diagnose the overheat condition.
TSB 05-1-2
2005 F250 6.0 PSD CC Auto, Dk toreador red/Ariz beige,Lariat Luxury 4x4 SB,TT Mirrors,Camper PKG,Roof lights,ADJ pedals,REV aid,Trailer hitch,TOW COMMAND,ESOF,PWR rear window,3.73 posi,SIRIUS SAT radio. Built 08/09/04
2005 F250 SIRUS RADIO
2002 BUYBACK bad paint F250 7.3 PSD Auto CC Lariat 4x4 SB, TT mirrors,Camper pkg,Grille insert,Hood shield,Tow pkg,Adj pedals,Shift on fly,Trailer brake,Spray in bedliner,Dk highland green w/tan.
2002 F250
south_paw is offline
Old 05-15-2005, 08:21 PM   #7 (permalink)
Mine did the exact same thing the other week when i was towing my 5th wheel home from the mountains. Gauge went to the red zone then the fan came on and after 5 - 10 seconds the needle dropped back to the normal zone. Called the dealer and he confirmed that this is normal.
2005 F350 DRW Lariat 4x4 C/C 8'box FX4. Every possible option minus moonroof. DPPI cat back with 5" tip, pyro and trans gauges with a piller mount, Leer 100XL, Bedrug, Delphi navigational system, XM Radio, Turbo life saver with secret switch, White Night back up lights.
dtmhomes is offline
Old 05-17-2005, 03:58 PM   #8 (permalink)
A temp gauge as an ididot light? Aurrgh!
At least they still put one in, some manufacturers are removing them completely, say the "annoy" the driver?!
dt_diesel is offline
Old 05-17-2005, 05:14 PM   #9 (permalink)
Both my Chevy and Dodge have actual engine and trans temp gauge with real numbers not just red and "normal". Of course, I did add the trans temp on the Dodge, but the Chevy came stock....
ramv is offline
