05 Truck with 04 engine? - Diesel Forum - TheDieselStop.com
Old 05-16-2005, 10:20 PM   #1 (permalink)
Hey ford doc's,
I have a january 05 but I noticed on what i think is the fcim an international sticker with eng#100 122204. Does this mean I have an o4 engine? If so is it built to 05 specs? I am wondering if i have the updated EBP,EGR, Flashes ect. I sure would like to know. Thanks in advance for your expertise. [img]/ubbthreads/images/graemlins/confused.gif[/img]
2005 f250 PSD 4x4,CC,LB Magnaflow 4" turbo back exhaust.
moovet is offline
Old 05-16-2005, 11:35 PM   #2 (permalink)
william_04_X's Avatar
Re: 05 Truck with 04 engine?
i know my 04 X has a sticker on passenger side valve cover with an 03 date for the engine..
04 EB X w/03 PSD
william_04_X is offline
Old 05-17-2005, 09:03 AM   #3 (permalink)
All its telling you is when it was built - 12-22-04. As the '05 model year started several months prior, I wouldn't worry about it being an '04
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 05-17-2005, 10:29 AM   #4 (permalink)
On that sticker on the valve cover, it should just have "2004" or "2005" in pretty visible type, sort of off by itself.
icon2004 (12/03) F250 6.0 PSD, TS, CC, LB, XLT Sport FX4 (Met Grey with Black Leather)
4.5" Edge lift, Fabtech 2.25 Shocks, UltraStart Remote Starter / Alarm, Tint, Prodigy, Valentine 1, MBRP Stainless Turbo-Back, 4000W Inverter, Ford AIC, X-Monitor, 16x10 MT Classic Locks, 35x12.50 ProComp Extreme AT's, Kobalt Low-Profile Toolbox (black), 4-chime train horn, 5 gallon air tank, air chuck, Viair 450c compressor, XM
Now Towing: Yamaha SX230 HO
Asynchronism is offline
Old 05-17-2005, 10:34 AM   #5 (permalink)
My Photos: (5)
Since an '04 6L won't fit in an '05 F-series Super Duty thanks to, among other things, a relocated steering gear, I don't think you have anything to worry about in that respect. A 12/04 engine build is well after the 07/04 start of 2005 model year engine production.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
Old 05-17-2005, 10:50 AM   #6 (permalink)
My Photos: (13)
I find that difficult to believe. I'll bet my 6.0L block will fit in the 03, 04, 05, and 06 SuperDuty trucks. I'll also bet my block will fit in 99 - 03 as well (motor mounts may have to be tweeked). Now there *might* be a slight change in location of accessories, such as alternators, PS pumps, and AC compressors. But come on now... Ford isn't going to change the engine to accomodate a new steering gearbox. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Finding an 04 built engine in an 05 truck is nothing new. Same thing happened between the 03 and 04 model trucks as well. Whether or not you got the specific changes for 05 remains to be seen. It all depends on when the switch over was made. For the 03 to 04 models, I believe the magic date was Sept 29th. So 04 trucks made prior to that date, actually got the pre-04 engine, and those made afterwards got the 04 engine revisions. Same, I'm sure, is happening here. That's why it doesn't pay to be the first one in line in most cases. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Happy Truckin,
Brian.
2004 F250 Lariat, Diesel 6.0L, 5spd auto,4x4 FX4, True Blue/Med Parchment, Camper Package, Cab lights, Dual Alternators, AIC, Power Sliding Rear window, 12.5k receiver hitch.
Add-ons: Headache Rack, Brush Guard, B&W Hidden Hitch & Daytime Running Lights, PIAA 520 series driving lights, boost/tranny gauges, Dahl 100 fuel filter/water separator, Prodigy brake controller, air horns, Sinister Coolant Filter.
In-the-works: Onboard air, Aux. fuel/Toolbox combo.
Ordered on: 03/29/04.
Arrived on: 04/28/04.
SIGNED: 05/01/04 Whoop!
Recall 04B24: Installed 02/15/05.
My Pics
6.0L Bible
PoppaSmurf is offline
Old 05-17-2005, 11:17 AM   #7 (permalink)
Don't forget about the physical differences between '04 and '05. I would agree that the updated front end may cause fit problems that don't exist between '03 and '04.
Mark
Built: 11/03/03
4x4Mark is offline
Old 05-17-2005, 10:27 PM   #8 (permalink)
Mine was manufactured in August of 2004, but sticker on motor cleary states "2005 motor, and lists the new horsepower and torque ratings."
06 F350 SC LB 4X4 FX4 Lariet 6.0 Torqshift, True Blue Clearcoat, tow command system. Toyo Mud-Terrain tires size 35/12.50//18 on stock wheels, Mag-Hytec rear differential cover, Bilstein shocks, and Alpine 9833 head unit, Kenwood Excellon speakers, and an Alpine V12 4 channel amp with 80 watts per channel RMS.
ronk54 is offline
Old 05-18-2005, 12:02 PM   #9 (permalink)
My Photos: (5)
Bare block, it'll fit in an '05. Complete assembly, won't fit. Steering gear runs into the '03/'04 water inlet on the front cover. PM me for the address to send the cashier's check. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Now, on the Excursion and Econoline, they're still using the '04-style front cover assembly (Econoline is even using the same part number, Excursion is only slightly different but enough to have its own part number). But the Excursion didn't get the front end changes the F-Series got.
As far as fitting in a '99-'03, you're looking at different mounts, radiator, charge air cooler, fan/fan shroud, overflow bottle, air induction assembly, at least the driver's side battery tray, heat shields & sound insulation panels, and damn near all the wiring in the front half of the truck.
If the truck has the '05 frame and front suspension, it will have an '05 engine. If it has the '04 frame and front suspension, it's not an '05, then, is it? [img]/ubbthreads/images/graemlins/laugh.gif[/img]
AutoJim
Former Cooling Guy
AutoJim is offline
