05B27 recall - Diesel Forum - TheDieselStop.com
Old 04-20-2005, 07:20 AM   #1 (permalink)
cec
05B27 recall
My dealer called yesterday to ask me to drop off my 05 F350 Lariat and was surprised that I was expecting his call. Thanks to this forum I was able to say, "what took you so long"? I have had this truck since November and am completely happy with it, having had no problems at all with it, my three other 05's and my 04. I just hope that the process of removing and tearing down the transmission does not ruin my luck. I ask those who have had this recall work done to comment on their experience. Thanks.
2005 F350 Super Duty extra cab Lariat Automatic, 4WD,FX4, dark Torreador Red with ARE cap (Ford buyback replacement for a leaky 03 XLT). 2005 F350 XLT Crew Cab Dually, 2004 F250 XL Super Duty reg. cab, 2005 F450 Box, 2005 F450 Dump bed, 2006 SLT Supercab dually, 3 2006 F550 supercab Dump beds, Custom 2006 F550 4 door Lariat 4X4 super hauler,2 2008 F450 crew duallies (and a whole lot of HD diesel equipment), and a 2006 Z06 for fun.
cec is offline
Old 04-20-2005, 10:08 AM   #2 (permalink)
Re: 05B27 recall
I had mine done in Febuary and it was the second one done at that dealer. Made me very nervous. Tech. did a great job. It took him two days. Make sure they order both kits because they won't know which one to use until they open it up.
Alan
'87 Mustang LX 5.0 5 spd. project car
'01 Escape XLT 3.0
'03 34' Cougar TT
'04 F350 CC 4x4 SB 6.0 PSD Lariet AZ Biege loaded Line-x bed liner Literider roll up bed cover
adkelly is offline
Old 04-20-2005, 12:29 PM   #3 (permalink)
Re: 05B27 recall
Had mine done in march, took about a day and a half. No major problems and about 1500 miles. My only advice is to check the auxillary trans cooler (front left of radiator)mine is leaking looks like they replaced the filter, but not the seal. You may want to even request the seal replaced when you drop it off. Good Luck...
05 F-250 SD Crew Cab 4X4 6.0L Diesel
badazzpolaris is offline
Old 04-20-2005, 08:30 PM   #4 (permalink)
Re: 05B27 recall
I had the recall done about a month ago. Brfore the recall I had a 1-2 second delay shifting from drive to reverse and the same from reverse to drive. After the three day recall the 1-2 secong issue became a 5-6 second one. The truck then went back in under warranty for a complete rebuild. After 6 buisness days it was ready. I got it back with the same issue that it went in for in the first place. It is going back in next thursday for another rebuild. Now it not only takes the 6 seconds to shift, when it does kick into gear it really kicks in. I mean that at this rate I will be lucky to get 10k miles out of the universals! Not only that, it shifts randomly while driving. (so far it only does it thru forward gears, not forward to reverse) I called other dealers and they all seem to be backed up with transmission issues. While the service managers may say that they are not having any problems with these transmissions the schedule speaks for itself. Good luck!
cthru1 is offline
Old 04-22-2005, 11:37 AM   #5 (permalink)
Re: 05B27 recall
Ok ....whats this 05b27 recall for??I have a 2wd 05'that i got in december and haven't heard about this from my dealer.Does this even effect my truck being that its a 2wd.
Thanks,
jeff
2005 f250 cc Lb 2wd PSD
rocky7184 is offline
Old 04-22-2005, 03:16 PM   #6 (permalink)
Re: 05B27 recall
i got my recall letter in the mail this week and am not sure about it either.....might wait until later on this summer when i'll have had it close to a year so i'll get a free transmission flush...keep us posted on how you come out...
2004 F-350 DRW 6-oh
Superchips 1704
Kenwood kdc-x979,(((XM Radio))),Eclipse Amp,
2 Eclipse 10's, Valentine One radar detector,
Air Raid filter, broken EGR valve connector (oops [img]/ubbthreads/images/graemlins/wink.gif[/img]),and can't decide what else to do...
txwalker is offline
Old 04-28-2005, 07:17 AM   #7 (permalink)
cec
Re: 05B27 recall
The 05b27 recall was done on my 05 Lariat yesterday and it seemed fine on the drive home. The dealer told me that they have been doing one recall a day for months due to the 04 recall and the 05 recall. Sad to see such poor quality coming from an American company. It must be costing them a fortune. Fortunately my transmission showed no signs of damage or metal fileings and hopefully there will be no future problems. While I was there I ordered an 06 crew cab 6.0 to replace my last remaining 99 Dodge Cummins.
cec is offline
Old 04-29-2005, 03:55 PM   #8 (permalink)
Re: 05B27 recall
Alan [/quote
Whats the difference between the 2 kits.And shouldn't the service writer know about the 2 different kits?????
Old 04-29-2005, 11:57 PM   #9 (permalink)
Re: 05B27 recall
Not sure what the difference is between the kits, but the S/W said on the one trans. they did before mine the kit they ordered was the wrong one and they had to order the other kit after they opened up the trans. When I scheduled mine, he said they would order both kits to avoid any delay.
Alan
'01 Escape XLT 3.0
'03 34' Cougar TT
adkelly is offline
Old 04-30-2005, 10:25 AM   #10 (permalink)
Re: 05B27 recall
Alan
I'll suggest ordering both kits to the service writer.I bet he don't do it.
Old 04-30-2005, 10:58 AM   #11 (permalink)
My Photos: (21)
Re: 05B27 recall
Here's a listing of all the parts under 05B27
PARTS REQUIREMENTS / ORDERING INFORMATION
Parts will not be direct shipped for this program. Order your parts requirements through normal order processing channels.
Part Number Description Quantity
5C3Z-7D483-W DIESEL SNAP RING KIT #1 - kit contents:
7A136 Pump-to-Case Gasket (1)
7C155 Solenoid Body-to-Case Gasket (1)
7D441 Pump OD Seal (1)
7G186 Sump Filter (1)
7N134 Front Pump Bolts (9)
7B421 Diesel Snap Ring - Reverse Clutch-to-Case (1) 1
5C3Z-7D483-Y GAS SNAP RING KIT #2 - kit contents:
7C155 Solenoid Body-to•Case Gasket (1)
78421 Gas Snap Ring - Reverse Clutch-to-Case (1) 1
XT-6-QSP TRANSMISSION FLUID Note 2
5C3Z-7D483-X KIT #3 (gas or diesel application - see note #3 below)
7C012 Remote Filter Element (1)
7086 Extension to Case Gasket (1)
7B155 Inline Filter Assembly (1) Note 3
5C3Z-7A095-CB OIL COOLER ASSEMBLY Note 3
5C3Z-7005-AA NON-PTO TRANSMISSION CASE ASSEMBLY Note 3 & 4
5C3Z-7005-BA PTO TRANSMISSION CASE ASSEMBLY Note 3 & 4
NOTE 2: Repairs using either Diesel Kit #1 or Gas Kit #2 require 15 quarts of Mercon SP. Repairs requiring the Kit #3 will need three (3) additional quarts.
NOTE 3: Required only when snap ring is either fully or partially dislodged.
NOTE 4: PTO and Non-PTO transmission case assemblies will fit either gas or diesel application.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 04-30-2005, 09:11 PM   #12 (permalink)
Re: 05B27 recall
Hey thanks for the parts list.!!!!
Old 05-01-2005, 09:33 AM   #13 (permalink)
Re: 05B27 recall
Well my truck is in for the third transmission rebuild. Took it in last thursday and hopefully I will have it back this week. (working like it should) I have not gotten a parts inventory yet. I am also getting my first reflash to hopefully cure the 13mpg highway issue and not cause others!
cthru1 is offline
Old 05-06-2005, 07:40 AM   #14 (permalink)
Re: 05B27 recall
Mine went in for the recall Tuesday morning. I got it back late Thursday. It drives & shifts the same as before it went in. 15k miles and no problems. This truck is absolutely awesome!!!
Chris
KA0BLT is offline
Old 05-06-2005, 01:59 PM   #15 (permalink)
Re: 05B27 recall
Chris
I was supposed to take my truck this week for the recall work.The service writer canceled my appt because he said my truck was not on the recall list.
I have an 05 crewcab longbed psd 4x2 with the camper pkg.What does everyone else have and WHY would'nt mine be included.I have the same trans as everyone else.Can someone please enlighten me.
thanks
