'06 Oil Cooler and EGR Delete - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 07-22-2012, 07:33 PM Thread Starter
Ty1
Ty1's Avatar
Talking '06 Oil Cooler and EGR Delete
Quick question. My local bulletproofdiesel.com dealer will do an EGR Delete and bulletproof Oil Cooler for around 2,900$$$$$$$$$$$$$$$$$$$.....One problem..........I don't have 2,900$$$$$$$$$$$$$$$$$$$$$.................So my plan is to delete the egr, then within' a month or two (10,000 miles) do the oil cooler. Being an 06 which has a fairly good reputation will my oil cooler last much longer or will I just have to get screwed..........Any help is great..... Should I do the oil cooler first even???? Thanks for all replies!!! Truck has 102,000 miles BTW.
Ty (Dukey)
2006
F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, DFUSER Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 w/ Custom Tunes from Matt @ Gearhead, Air Lift Load Lifter 5,000s w/ On Board Compressor System, My POV~~
Early 2004
F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008
F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
LONG GONE>>400,000 MILES!!!~~1999
F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Ty1 is offline
post #2 of 14 (permalink) Old 07-22-2012, 07:51 PM
What is the temperature difference between the oil and coolant after you completely reach operating temps?
Mark
bismic is offline
post #3 of 14 (permalink) Old 07-22-2012, 08:41 PM
rock_doctor's Avatar
The reason bismic asked your temp difference is because the oil cooler does not really need to be changed until there is a 15F or more difference between the oil temp and the coolant temp. Technically since you are doing an egr delete the temp difference becomes moot as the difference was fords way to "guess" if there was enough coolant coming out of the oil cooler to cool the egr cooler. So no egr cooler then you could technically ignore the oil cooler unless it is leaking or you are getting super high oil temps. Really, if you can do the egr delete you can also do the oil cooler replacement. It is not that hard, just tedious. There are tons of videos on utube. Give them a look and see if you want to jump in. Most owners just do the oil cooler and delete themselves. The hard part is getting the turbo out and changing the up pipe because the bolts are not captured. You have to put a wrench on the top and bottom of the bolt. And they are not easily accessible, although in my case i welded the bolts to the new up pipe before installing it. So getting out the old one took two hours, putting in the new one took 20min (the long bolts go on the sliding flange which bolts to the manifold)...
rock_doctor is offline
post #4 of 14 (permalink) Old 07-22-2012, 11:06 PM
yatespread's Avatar
I am going through the same deal with my 06. What's better egr delete or bullet proof egr. My price was 2800 in San Angelo
2006 F350 King Ranch 4X4 4dr drw 6.0 auto, 4.10 L/S,
SCT livewire
PHP ficm tuner
Bulletproof oil and egr coolers
DC power 270xp
Muffler deleted.
Banks Techni Cooler
Banks Ram air filter.
yatespread is offline
post #5 of 14 (permalink) Old 07-23-2012, 12:38 PM Thread Starter
Ty1
Ty1's Avatar
The truck has ran normal and great. I did lose the turbo a month or so ago due to an oil tube blowing up inside it. temps all seem normal and not a leak. I will go ahead and buy a therometer and test the temps before I do anything......sounds like a great and easy test.
Ty (Dukey)
2006
Early 2004
2008
Ty1 is offline
post #6 of 14 (permalink) Old 07-23-2012, 12:41 PM Thread Starter
Ty1
Ty1's Avatar
My price was 2500 here in Colorado for the Bulletproof egr and oil cooler and an extra 400-600 roughly for the delete and oil cooler since you have to add the sct tuner price.. I'd much rather do the delete so I don't have to deal with the soot on the egr valve and maybe get that extra 2 mpg.
Ty (Dukey)
2006
Early 2004
2008
Ty1 is offline
post #7 of 14 (permalink) Old 07-23-2012, 01:15 PM
F350MudBogger's Avatar
My Photos: (10)
Its kinda a double edge sword, Since your gonna be in there you could just change out the oil cooler as preventive maintenance, But if you get the Bulletproof oil cooler, You will have to go back in there to remove the oil cooler and replace the top plate with the Bulletproof part. I run a Bulletproof EGR Cooler with the EGR valve "deactivated" (they put a value in that it will never reach so it doesnt open & close.) When your in there make sure you clean out your intake as it will have a nice coating of soot inside, Best to have it hot tanked at a radiator shop. Clean all the soot off the sensors on the intake, The biggest pain was, as previously mentioned, Seized turbo bolts & getting all that exhaust plumbing back in correctly. It does make it easier to install if you deleted the EGR cooler though. If you do a delete make sure you run a tuner that will allow you to "delete" the egr valve so u dont get a code.
06' F250 Lariat 4x4 CC SB 6.0 PSD
01' Excursion Limited 4x4 7.3 PSD
04' Ford Chassis Fleetwood 32' Motorhome
06'-VW Jetta TDI
(Sold after 2 engine oil leaks in 8k miles) 2009 Oxford White F250 6.4 PSD Lariat 4X4 CC LB
F350MudBogger is offline
post #8 of 14 (permalink) Old 07-23-2012, 01:27 PM
If you do it yourself (and you should try) get a new set of turbo bolts from ebay or your local ford dealer. It comes with the oil line gaskets/o-rings. I would also invest the $300 in a set of digital gauges. I prefer the Edge Insight, it plugs into the OBD2 port and tells you everything except for oil pressure, egt and fuel pressure. It is a great way to monitor voltages, temperatures and so on plus will let you read codes and clear codes... I made it a point to spray PB Blaster on all bolts before trying to remove them and not a single one was stuck. They all came out w/o issues. Great stuff!! Walmart sells it.
post #9 of 14 (permalink) Old 04-01-2015, 09:54 PM
i ran into the same issue with my truck. i did the egr delete and not even 12 hours after picking it up my check engine light is on has anyone had this problem after their delete
allecrshippiv is offline
post #10 of 14 (permalink) Old 04-02-2015, 07:56 AM
It may be that you need a tuner to turn off the CEL.
What code are you getting?
What year truck do you have?
Mark
bismic is offline
post #11 of 14 (permalink) Old 04-02-2015, 09:51 AM
those prices are crazy why not just plug your egr in and zip tie it up like alot of people have done.i personally wouldn't waist my money on said products.you could weld your egr cooler up and buy the so call high flow oil cooler off ebay.i can tell you how to build your own set up and you can save over 1800 or so and you will love it.if you are mechanically inclined you can do this no sweat and you will be glad you did.
excutioner is offline
post #12 of 14 (permalink) Old 04-03-2015, 01:47 AM
I'm getting the egr code my truck is 06 model. I found out today this code will come up after the delete unless you guys know of a way to remove it. The egr valve is still in the truck and as a couple of months old. How much is a tuner and what is a good tuner to purchase for this truck
post #13 of 14 (permalink) Old 04-03-2015, 07:46 AM
SCT tuner and custom tunes from a good source (like Gearhead)
Mark
bismic is offline
post #14 of 14 (permalink) Old 04-03-2015, 09:11 AM
323flint is offline
