'06 PSD Heated Mirrors ? - Diesel Forum - TheDieselStop.com
Old 09-10-2006, 08:37 AM   #1 (permalink)
Is it true that the heated mirrors on the PSD '06, 6.0's are on all the time? OR is there a sensoir that turns them on at a certain temp, like 40`?
Can't believe these are on 24x7x365! Let me know please . . . [img]/ubbthreads/images/graemlins/shrug.gif[/img]
BtLW / Houston, TX
2006 SD 6.0 CC/SB Lariat/King Ranch/Fx4, Dk Copper
lonewolftx is offline
Old 09-10-2006, 08:49 AM   #2 (permalink)
Re: '06 PSD Heated Mirrors ?
heated mirrors are on when ignition is on or in accessory delay mode
2010 F350 CC, SRW, SWB, 4x4, V-10,Torqshift, 4.10LS, XLT, Bright Red, Med Stone 40/20/40 Pwr Seats, Single CD with Sirius and Sync, Tow Command, Pwr Scope Mirrors, ESOF, FX4, Chrome Tube Steps, Cab Lights, 18" OWL A/T Tires, Forged Aluminum Wheels, Snow Plow Prep Pkg, Reverse Sensors, Advance Security Pkg.
Remote Start, Rhino Liner.
2005 Open Road 357 5th wheel.
Reese 20K Select Series 5th wheel hitch w/ round tube slider.
shark1955 is offline
Old 09-10-2006, 09:09 AM   #3 (permalink)
So I need to add a switch, like #3 upfitter, to turn these suckers off? Like I need heated mirrors 24/7/365 in Houston TX.
BtLW / Houston, TX
Old 09-10-2006, 09:10 AM   #4 (permalink)
I have an 05 and had thesame question. I left the ignition on with to listen to the radio when cleaning it and left it that way when I washed the truck. Before I could dry the truck, the mirrors were dry and hot.
first_ford is offline
Old 09-10-2006, 10:20 AM   #5 (permalink)
What wire is it that run's the heated mirrors from the fuse panel? There is blk w/ white tracer at the mirror it self but none coming off the fuse panel.
Thks!
BtLW / Houston, TX
Old 09-10-2006, 10:25 AM   #6 (permalink)
will an up fitter switch take care of the on all the time heated mirrors? Seems funny to have to do that ,or is it just a Ford thing.
2005 Ford XLT
6.0 Torq Shift SWB 4X4 Camper Pkg
17in Pir. chrome Tube Steps
Wedgewood Blue/Ariz.
Lund Bug/Ventshades 35% Tint Windows
Tonno. Cab Lights
Saddleblanket Seat cov.
dennispd is offline
Old 09-10-2006, 10:28 AM   #7 (permalink)
Also if someone could find a ford part # for a factory appearing switch for mirror heat that would be a big help as all of my upfitter switches are in use
thanks
'06 F250 AFE STG2, SCT XCAL 2... MORE TO COME
'02 F350 CC SWB - STOLEN
'99 F350 EXT SWB - SOLD
'79 F250 - BEST ONE YET
lefty 1977 is offline
Old 09-10-2006, 10:34 AM   #8 (permalink)
I know the F150's had a factory switch for that so you might check there.
BtLW / Houston, TX
Old 09-10-2006, 10:36 AM   #9 (permalink)
It can be wired to switch the miorrors on and off. That is why I want the wire color to rewire it. [img]/ubbthreads/images/graemlins/eek.gif[/img]
BtLW / Houston, TX
Old 09-10-2006, 11:32 AM   #10 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
Here is the answer that I sent to a another subscriber. The only thing to remember is to use the number one or two upfitter switch since the mirror heat is about ten to fifteen amps. I actually cut the wire from the fuse panel and attached the end that goes into the wiring harness to the number one upfitter. I then took the other end coming out of the fuse box and attached a female bullet connector. This gives me another fused ignition on power source. It is easiest to remove the four bolts that hold in the fuse panel and pull it forward. The wire you want is on the middle connector, on the back of the fuse panel. It is on the left side of the connector, second from the bottom. It is green with a purple strip. You can double check by hooking up a test light or meter and turning the ignition on. It will then show hot(12v). Next remove the fuse for the mirror heat and retest. If it is cold you know you have the right one. Cut the wire about an 1 1/2 from the fuse panel and strip both ends. Put a connector(bullet or butt) on the end coming from the fuse panel and attach the other end to the upfitter wire of your choice.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 09-10-2006, 01:30 PM   #11 (permalink)
Thanks, that is what I needed to know. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Where did you get the glove light box? I found them on the internet for $12.95 but they want $12 to ship. Any better option? [img]/ubbthreads/images/graemlins/confused.gif[/img]
BtLW / Houston, TX
Old 09-10-2006, 01:42 PM   #12 (permalink)
u pull it salvage yard for the glove box light. Most will give them to you.
blakerj10 is offline
Old 09-10-2006, 06:46 PM   #13 (permalink)
ritschner's Avatar
They are about $8 from First Ford Parts. I am not sure about shipping. It is also the same glove box light that is use in the Taurus if you decide to go junk yard hunting.
