06 starting problems - Diesel Forum - TheDieselStop.com
Old 03-04-2009, 04:13 PM   #1 (permalink)
06 psd with 84k miles will start just fine when its cold, but has trouble starting after it has been ran. any suggestios?? thanks in advance
JJ
jkkblakeley3 is offline
Old 03-04-2009, 11:07 PM   #2 (permalink)
Jimn8or's Avatar
I went thru this recently...The IPR [Internal Pressure Regulator] needs 500 PSI on start up in order to allow the start sequence. I was told it could simply be that you are using 5W20 oil and when the truck is warm/hot it doesn't have the viscosity to get past the IPR 500psi minimum, or maybe the oil qty is low. I see that most guys are running 15W40 on these types of boards which would help eliminate the above mentioned problem...However, if you have luck like I do...here is what my deal was: There is a fitting on the IPR that was improved from 06/06+up PSD's. My truck is a 05/06 production and had the old fitting on the IPR, which leaked like a bugger when hot which left me waiting for a tow truck recently. Be certain you tell your Ford Dealer about this upgraded IPR fitting when you drop it off or you'll be waiting a freaking week for your ride like I did
HTH
Jim
Jimn8or is offline
Old 03-07-2009, 06:08 PM   #3 (permalink)
sounds like a high pressure oil leak. stc fitting is common, as well as the D-rings on the hp oil rail plugs.
djshum is offline
Old 03-08-2009, 06:50 PM   #4 (permalink)
I also just went through this. And mine had 84k as well. Took 7 to 10 seconds to start. Finally would not start at all. Had it towed in to dealer. After replacing the SCT fittings and the galley plug O rings or D rings. all was well.
They also replace #6 injector to cure morning sickness when cold. Took about 5 to run smoothly until warmed up.
2006 250SD, Crew Cab, 4x4, Lariat, 6.0 Diesel.
Stevecar is offline
Old 03-09-2009, 01:03 PM   #5 (permalink)
thanks everyone for you help, very much appreciated
Old 03-11-2009, 03:06 AM   #6 (permalink)
what is the stc fitting? all his sounds like what my 04 is doing it just started tonight
jph5413 is offline
Old 03-11-2009, 06:20 AM   #7 (permalink)
RatherBNtheWoods's Avatar
STC(snap to connect) is a quick disconnect type fitting used on the hig pressure oil system. It was used on some year model 6oh's, but turned out to be unreliable. Actually, it seems that you can rely on it. To fail at some time, sooner or later!
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
